Paging in between bridged PBX's
Discussion in '3CX Phone System - General' started by jpillow, Feb 16, 2013.
  1. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I have two locations each with 8sc licenses, the systems are bridged using 3cx tunnel. Is it possible to use intercom in between locations?
