Paging interruption on SPAxxx
Discussion in '3CX Phone System - General' started by leviticus, Nov 12, 2011.
  1. leviticus
    Nov 12, 2011
    10
    So, I'm sure most know that with the Cisco phones, when a page comes through, by default with 'Auto-answer page' enabled, it will place an active call on hold. Alternatively, setting 'Auto-answer page' to 'off' will make the handset never answer a page (while on a call or not).
    For context: For my purposes, I'm always paging to a group, not a PTT type situation.
    So, after much Googling, it seems the most popular solution is making the phone system check to see if there's an active call before sending the page.
    A few questions:
    -Has Cisco firmware changed in such a manner that the page will mix the call and page audio?
    -Can 3CX do the 'active line check', and if so how?
    -Would there be implications to the 'active line check' such as.. If one phone is busy in the page group, would it cause that entire page to fail, or simply only page the other members of the page group? (The latter being my desired behavior.)
    Any guidance or thoughts would be greatly appreciated!
  2. talward
    Nov 21, 2011
    What did you google.. I'm having that current problem and trying to come up with a solution. Because what I've heard is that this is not a feature in 3CX and will be added in the next version.. Do you hard code the phones or is it something provided in the auto provisioning?
  3. glulfurfisa
    Nov 22, 2011
    paczki świąteczne
    Good day!
    I've recently come across
    amazing
    Kosze prezentowe
  4. efounco
    efounco New Member
    Sep 28, 2011
    148
    With 3CX, if you DON'T have the "I want to be able to receive more than one call at a time" option checked, the system will detect the status of the extension and will not send a page to phone if it is busy. However, if you need to accept multiple calls and have this option checked, it will do as you described and put the other call(s) on hold during a page. This seems to be the norm with all Cisco SPA phones regardless of their firmware revision.
    Instead of tying up a bunch of phones during a page (which causes our BLF/switchboard to go nuts), I decided to connect a couple of spare/inexpensive VOIP phones to a 70v overhead system. It was fairly inexpensive and saves me a lot of grief when paging.
