Paging not working
Discussion in '3CX Phone System - General' started by gunners, May 13, 2015.
  1. gunners
    Nov 6, 2014
    20
    We have upgraded from version 11 to version 12 and since the the *9 for paging is not working. This was working before that but now is not.
    I have checked under Settings>Advanced and it is still there as paging *9
    Version at the moment is 12.5.39117.982
    Under updates there is a "Service Pack 1" update, will doing that fix this issue?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    419
    62
    Are you using *9 for set-to-set paging (e.g. Intercom page) or are you using it through a Ring Group set to Paging with multiple sets selected?
    If you are using set-to-set paging (intercom) then you have to update the permissions on the extensions tab for the extension grouping to enable intercom. The extension permissions changed drastically from v11 to v12/v12.5.
    If you are using Ring Group paging give more detail on how it is failing.
