Panasonic Dect TGP500
Discussion in 'Windows' started by jpillow, May 5, 2012.
  1. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    For some reason I cannot get the web GUI for this phone to open, to register to 3cx. Has anyone else seen this issue before while trying to register this handset/=?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    If your handset is connected to the base, push the joystick then enter #534 1 to enable the web port.
  3. jpillow
    Jun 20, 2011
    1,342
    Yes I found out you have to configure these to enable webport before accessing everytime. however my vendor is suppose to be sending me a config to combat thatl
