No, the phone works with 3CX without issues, I have more than 20 pcs manually configured for a customer, as well as HDV230 (including BLF buttons). They preferred them because of white color.Yes, i am aware of the downside of an unsupported phone, i just wanted to check if anyone actually succeeded in making them work.
I know how to set a phone up manually without provisioning, i have some yealinks set up like that, but the Panasonic refuses to register.
It seems it just wont work with 3CX, too bad.
I wonder what i am doing wrong thenNo, the phone works with 3CX without issues, I have more than 20 pcs manually configured for a customer, as well as HDV230 (including BLF buttons). They preferred them because of white color.
I also have 2 gigasets setup- will compare to those too...Thanks, appreciate it.
Will have to double check i put the address in all the fields tomorrow since i have left the office right now.
One thing to note is that i am trying to register through vpn, the ip of the phone is 192.168.1.xx and the 3CX server is at 192.168.0.xx .
Yealinks work fine, maybe the panasonic needs some tuning, will give it some more time tomorrow.
Thanks again.
There is nothing special about VPN, you have to configure the phone as working in the LAN segment of the PBX, no NAT, no STUN.Thanks, appreciate it.
Thanks again.
Check whether they register to 3CX PBX with their local address from remote network, via VPN, i.e. 192.168.1.x.I also have 2 gigasets setup- will compare to those too...
If VPN is properly configured, this is not needed, in contrary mask 255.255.0.0 will disrupt operations.If you are manually configuring, just set the subnet mask of the set, as 255.255.0.0...if needed.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
