3CXusername
- Joined
- Jul 31, 2014
- Messages
- 186
- Reaction score
- 16
Good Day,
Ring group doesn't ring all handsets. Often random handsets.
3CX Log example (with no other concurrent calls):
Dev:sip:[email protected]:5090] from L:1672.1[Line:10001<<5559995555] failed, cause: Cause: 486 Busy Here/INVITE from 10.1.101.53:5080
01-Dec-2014 09:43:22.374 [CM503003]: Call(C:1672): Call to <sip:[email protected]:5060> has failed; Cause: 486 Busy Here/INVITE from 192.168.101.53:5080
01-Dec-2014 09:43:22.354 Leg L:1672.4[Extn] is terminated: Cause: 486 Busy Here/INVITE from 192.168.1.53:5070
01-Dec-2014 09:43:22.350 Call to T:RingAll:9000@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5070,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5080,
Dev:sip:[email protected]:5090] from L:1672.1[Line:10001<<5559995555] failed, cause: Cause: 486 Busy Here/INVITE from 192.168.101.53:5070
01-Dec-2014 09:43:22.334 [CM503003]: Call(C:1672): Call to <sip:[email protected]:5060> has failed; Cause: 486 Busy Here/INVITE from 192.168.101.53:5070
01-Dec-2014 09:43:21.561 [CM503025]: Call(C:1672): Calling T:RingAll:9000@
Setup:
*inbound rule (main DIDs) to Ring group (9000) to 4 handsets
*Panasonic: One base (KX-TGP500B04 fw12.90) and 4 handsets (KX-TPA50).
*3CX v12 SP6.1 Pro (4 SC)
*Using 3CX panasonic_kt500.ph.xml template
*1:1 - Handheld to Extension.
Anyone have any ideas?
thanks.
Setup:
thanks.
