Panasonic KX-UDT111/ Windows Client Issue
Discussion in '3CX Phone System - General' started by JS_VNET, Jun 27, 2014.
  1. JS_VNET
    Jun 18, 2014
    Hi all
    Sometimes when someone calls me only the softphone client is ringing. I checked the VoIP Status of my PS and it tells its OK. When i reboot the PS it works in most cases. But not always.
    there are 2 Computers and the Android Client that are connected with the same extensions. Can this simultanious use cause the problem?
    Thanks in Advance
    JS
    Panasonic CS KX-UD124CE Error_Log: (Antenna)
    Date Time ErrCd Er Line Fc Cod Description
    FF/FF FF:FF:FF 31005 The number of PS location registration became within range.
    FF/FF FF:FF:FF 30005 In service.
    FF/FF FF:FF:FF 20007 192.168.142.200 IP Address is acquired.
    04/11 09:41:00 20010 Network link error.
    04/11 09:41:16 20000 Network link established.
    04/11 09:41:49 90001 001 00001 002 Server connection error. No Response.
    04/11 09:42:20 20010 Network link error.
    04/11 09:42:33 20000 Network link established.
    04/11 09:43:23 20010 Network link error.
    FF/FF FF:FF:FF 30003 Master CS starts.
    FF/FF FF:FF:FF 31004 The number of PS location registration exceed the limitation.
    04/15 10:01:28 30005 In service.
    04/15 10:08:44 30005 In service.
    04/22 12:27:57 90001 001 00010 003 00404 Server connection error. SIP Error (ex. 404).
    05/01 21:53:41 90001 001 00008 002 Server connection error. No Response.
    05/01 21:55:30 90001 001 00009 002 Server connection error. No Response.
    05/01 21:55:31 90001 001 00010 002 Server connection error. No Response.
    05/01 22:00:51 90001 001 00003 002 Server connection error. No Response.
    05/01 22:00:51 90001 001 00004 002 Server connection error. No Response.
    06/06 14:55:07 30005 In service.
    06/06 15:09:09 30005 In service.
    06/16 13:12:44 30005 In service.
    06/16 13:13:31 30005 In service.
    06/17 13:45:07 90001 001 00001 002 Server connection error. No Response.
    06/17 13:45:08 90001 001 00002 002 Server connection error. No Response.
    06/17 13:45:09 90001 001 00009 002 Server connection error. No Response.
    06/17 13:45:10 90001 001 00010 002 Server connection error. No Response.
    06/17 14:02:17 90001 001 00003 002 Server connection error. No Response.
    06/17 14:02:18 90001 001 00004 002 Server connection error. No Response.
    06/17 14:32:22 90001 001 00009 002 Server connection error. No Response.
    06/17 14:32:23 90001 001 00010 002 Server connection error. No Response.
    06/17 14:33:12 90001 001 00009 002 Server connection error. No Response.
    06/17 14:33:13 90001 001 00010 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00001 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00002 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00003 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00004 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00009 002 Server connection error. No Response.
    FF/FF FF:FF:FF 90001 001 00010 002 Server connection error. No Response.
    FF/FF FF:FF:FF 20010 Network link error.
    FF/FF FF:FF:FF 20000 Network link established.
    06/26 19:12:22 90001 001 00009 003 00407 Server connection error. SIP Error (ex. 404).
  2. JS_VNET
    Jun 18, 2014
    It seems its unregister the PS somehow from the SIP Server but not all PS on the CS, only the one that I use.
    After a reboot of the CS the calls get forwarded to the PS.
    Any suggestions would be nice thanks!
