Panasonic TGP550 Dessk Phone and Base
Discussion in '3CX Phone System - General' started by thames, Sep 19, 2011.
  1. thames
    thames New Member
    Apr 4, 2011
    109
    Does anyone have experience with this phone and its handsets? I've bought one for the office because one of the folks here wanted a DECT phone. It seems to work with 3CX fine except for the answering process on the phone. When one picks up the handset on the base station (incoming call) the call is not answered but the little phone symbol on screen moves to the second one of three in the line. Then, if the person puts the phone handset down on the cradle briefly, then picks it up again, the phone answers the call just fine. Head scratching going on here big time!
    Cheers
    Chris
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    I use these in several installs. While I have not experienced your issue, it sounds like you need to use the web interface to the phone and look at the mapping sections of the base and the handsets. This defines how the lines or accounts are established for the base, which are availablebe to the cordless handsets and again which is a default for each. Also, what firmware is the phone using?
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try upgrading the firmware of the phone:
    http://panasonic.net/pcc/support/sipphone/
    There were some issues with earlier firmwares.
    Regards
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I find that only happens with queue calls. To fix that edit the extension within 3CX and turn off "Supports Replaces Header"
  5. thames
    thames New Member
    Apr 4, 2011
    109
    Thanks, Kerry
    Will try that!
    Cheers
    Chris
