Panic Button or Phone Off Hook Notification?
Discussion in '3CX Phone System - General' started by rob321, May 27, 2014.
  1. rob321
    May 27, 2014
    Greetings,
    I was wondering if anyone could tell me if the below is possible with this phone system and the best way to accomplish it.
    A mapped button or moving the phone off hook to act as a silent notification to a group of phones. The thought is the user is in trouble and needs to silently notify someone of the issue. The recipient would see the caller id and know to check on that person. While the people in the calling room would not know anything was going on.
    I know there are other ways to accomplish this but we would prefer to use the phone system.
    Any and all responses appreciated. Thanks.
    11,262
    355
    Many ATA's, and some VoIp phones have a "hotline" feature, Failing that, an off-hook "speed-dial" number can usually be programmed in the sets internal dialplan, if the set has one.
    I'm familiar with it's existence on the Linksys SPA series, but, I'm sure that there are a number of others.
    Of course, implementing this feature, on a single line phone, means that it can no longer place any other outgoing calls. A button, along with a resistor (to simulate a set), connected to an ATA might work for you as well, if you have spare FXS ports.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    try to visiti , cyberdata.com they have many device ...
  4. tom_ch
    Jul 6, 2011
    69
    http://www.voipsupply.com/cyberdata-voip-call-button
  5. charlieboyt
    Nov 15, 2014
    Yes as the post before me said the CyberData Call Button, SIP Panic Button. I have used this, you can configure it to call a pre-programmed extension on the phone network. Pretty easy to set up, cat5e and POE. http://www.ientrysystems.co.uk/
  6. jasit
    jasit New Member
    Feb 12, 2013
    173
    With the yealink phones, they have an option for using the buttons to access xml browser (basically a webserver that responds with xml pages. So if you program the button to include the extension that it's coming from, you could create a internal website that does email notifications which could include the location of the phone that triggered the emergency notification.
