Parameters options missing from Troubleshooting
Discussion in '3CX Phone System - General' started by Scott Cole, Jul 29, 2017.
  1. Scott Cole
    Jul 29, 2017
    When using 3CX 14 in virtual PBX mode, is there any way to access "Parameters" in virtual PBXs? The "Parameters" menu item isn't in the web interfaces when 3CX is setup in virtual PBX mode.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    If you are referencing Cloud Hosting - I think it is not.
    (I recall reading this at one point)
