Park and Un-Park calls using dial codes V. 15.5
Discussion in '3CX Phone System - General' started by Brian Cross, Nov 1, 2017.
  1. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    Does this article still apply? I can't get it to work with version 15.5 and yealink phones.
    https://www.3cx.com/blog/docs/call-parking/
    To park a call should just be a blind transfer to *05 (*0 to park and 5 being the number of the parking orbit)
    To unpark a call it should just dial *15 (*1 to unpark and 5 the number of the parking orbit).
    What am I missing? Thanks.
  2. Archie Frederic
    Jan 31, 2017
    69
    This should work fine. could you check your activity logs ?
  3. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    Note that the parking orbit is not the same thing as SP1-SP9.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,374
    278
    Hello @Brian Cross
    Please note that this is how Parking orbit works and the documentation still applies. What is the issue you are facing?
  5. Brian Cross
    Jul 26, 2017
    109
    27
    I wasn't able to park a call via the dial codes. I called myself from my cell phone, attempted to park via the dial codes and could not successfully. I'll have to look at the logs in more detail when time permits. I just wanted to make sure I was doing it right per the article..
    I understand parking orbit is not the same as SP.
  6. Archie Frederic
    Jan 31, 2017
    69
    @Brian Cross can you provide a wireshark capture of your pbx? I was actually hoping that you could identify the problem through analyzing the activity logs.
  7. revilo951
    Nov 12, 2016
    17
    I had the same issue, until I realised that the Shared Parks and the Parking Orbit are not the same thing. Maybe double check which you are using?
  8. jbryant84
    Apr 6, 2016
    106
    38
    Under Extension options>Rights make sure that Can Park Calls is enabled. This is disabled by default and I believe applies to the parking orbit, but not shared parks.
