Solved Park Keys
Discussion in '3CX Phone System - General' started by Tarheels, Dec 6, 2017.
  1. Tarheels
    Dec 22, 2016
    34
    My park keys show they are registered but when they are pushed they say park failed unknown
  2. tvdir
    Feb 17, 2017
    62
    15
    Can you see anything in Activity Log when trying to park a call?
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi Tarheels,
    What handsets are you using and what firmware version are you running on them ? Or is this issue using the Park keys on the Soft-client ?
    https://www.3cx.com/sip-phones/
    What do you see in your logs ? you may get an error - for example:
    Call to sip:SP1@127.0.0.1:5060 has failed. Cause: 486 Busy Here, from IP: 127.0.0.1:40000
    Reason: Busy.
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,102
    166
    eddv123 likes this.
  5. Tarheels
    Dec 22, 2016
    34
    I am using firmware 28.82.0.20. 3cx Version 15.5.5 standard edition
  6. Tarheels
    Dec 22, 2016
    34
    I put the phone back to firmware 28.81.0.110 and now the park keys work. 3CX says that isn't a supported firmware version.
  7. Saqqara
    Mar 12, 2014
    1,102
    166
    Std template or custom ?
    You will get the message about the firmware, as 3CX is highlighting your are running a previous version - you can ignore it
  8. Tarheels
    Dec 22, 2016
    34
    Standard. So I shouldn't upgrade the firmware when I see it not supported in 3cx
  9. Saqqara
    Mar 12, 2014
    1,102
    166
    As it would appear you had issues, and going back has resolved it - i would not upgrade yet until you can resolve the issue
    You could
    1. Check for templates updates
    2. Check the blf keys, under the extension to see if these are correct
    3. Upgrade one phone firmware, and re-provision the phone to see what happens
    How are the phones connected - local lan, sbc or stun
  10. Tarheels
    Dec 22, 2016
    34
    The phones were local but i am putting them on a sbc.
  11. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Why ? For what reason ?
  12. Tarheels
    Dec 22, 2016
    34
    The park keys were losing registration
  13. sip.bg
    Nov 7, 2016
    704
    219
    There should be other issues then, either with your network or with the firmware of phones. Try upgrading to latest supported firmware and reprovision them, as Saqqara advised and try to identify the issues, if continued, with Wireshark.
    If not a firmware bug, there should be a distinct reason for losing registration.
  14. Saqqara
    Mar 12, 2014
    1,102
    166
    Could try resetting the phones, and reassigning to the extension.
    Press the 'OK' button on the phone until you get 'Reset to Factory default'
    Delete the phone against the extension with console
    Reassign the phones to the extension
    As above, no need to run SBC on an internal network setup - are the phones and server on the same network address range ?
  15. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    I had the same problem and solved it by setting park settings like this:
    park.PNG The key was clearing the park codes which were needed in previous version. IT works with park enabled or disabled as 3CX handles this.
  16. jrjohnson
    Oct 4, 2016
    36
    I've been working with Yealink regarding this issue and I may have located the fix. It seems that I had to manually add an option to the provisioning templates that is not present by default.
    features.call_park.park_mode=2
    ## It configures the call park mode. 0-XSI, 1-FAC, 2-Transfer
    @jimbo59 You're fix wouldn't work for me as 'Transfer' isn't an option in my particular phone for some reason. FAC was the only option after the upgrade to the newest firmware.
  17. StefanW
    Jun 2, 2009
    1,216
    88
    I have passed this onto our IOT team of IP-Phone to check.
  18. StefanW
    Jun 2, 2009
    1,216
    88
    After contacting Yealink, the default value of this field should be in all V82 Firmwares Transfer.
    However to ensure the setting, it will be added in the template.
    In case you dont have this option at all in the GUI of the device, you must contact Yealink directly as this is nothing which can be controlled by 3CX.
