Parked Call Reminder
Discussion in '3CX Phone System - General' started by bolton, Nov 24, 2010.
  1. bolton
    Aug 10, 2010
    19
    Is there anyway of having a Parked call reminder, i.e. make the ahndset beep or have the parked call ring back into a call group. I have a customer that is "forgetting" about parked calls and their callers are complaining. This problem is magnified a little by the fact that the customer has a few MAC's with no Assistant to fall back onto.
    Anyone have any idea's?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    There is no parked call reminder avaialable on 3CX, that would call the user an notify them. You can post a feature request on ideas.3cx.com.
