Parked Calls and MOH
Discussion in '3CX Phone System - General' started by batescorp, Feb 5, 2014.
  1. batescorp
    Nov 26, 2013
    I am trying to figure out exactly which file I need to change in order to change my music on hold. Here is the problem I have. A call comes in and the caller is put into a shared parking spot. When I push the *SP0 the caller hears the correct music until a hang up the headset, then it switches to the incorrect music file. I have changed the file in the 'General - Music on Hold'. Can't find any other place to change the file.
  2. batescorp
    Nov 26, 2013
    Finally found it. Under the 'Settings', 'Advanced', 'Call Parking' there is another setting for music on hold. Had to change it there.
  3. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I just submitted a feature request on this, I would like to see the ability to set up random
    MOH files for shared parking just like you can for the 'on hold" calls
    https://apps.facebook.com/threecxideas/index.php?page=idea_detail.php&i=1128
