Parked calls drop
Discussion in '3CX Phone System - General' started by brgproducts, Nov 4, 2016.
  1. brgproducts
    May 24, 2016
    6
    Hello all, we are running version 14, SP3, using Yealink T29G phones. Whenever we place an outbound call, outside our system, the call goes through with out problems. If we try to park that call, it goes to the park and then drops in less than 2 seconds. I can repeat this over and over again.... Any ideas on how to resolve this?? Placing inbound calls or internal calls on park is not a problem...
    Thanks in advance,
    Bill
  2. brgproducts
    May 24, 2016
    6
    This problem has been fixed! Thanks to Kent at Sip.us. He told me to uncheck the "Supports Re-Invite" on the trunk settings....
