Parking Orbits 50 Limit Increase
Discussion in '3CX Phone System - General' started by DFP, Feb 14, 2018.
  1. DFP
    DFP
    Nov 3, 2015
    11
    Is the parking orbits 50 slot limit hard coded or can it be worked around. We are again looking at replacing our phone system. We currently use 48 park keys in our current system. Let me explain why.
    We now have 16 branch each branch gets 3 park keys. We do not want other branches picking another branches parked call. If we add another branch we will be over 3CX limit ie 51 parking orbits keys. Is there a work around to increase the parking orbit feature to greater then 50?
    #1 DFP, Feb 14, 2018
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @DFP
    Please note that currently there is no way to increase the number of shared parking past 50 as that is the limit.
    You can however create a feature request in our ideas section of the forum where it can be upvoted and evaluated by the appropriate department.
  3. DFP
    DFP
    Nov 3, 2015
    11
    Yep I did four years ago. Does 3CX allow a customer to pay for custom programming?
  4. YiannisH_3CX
    May 10, 2016
    7,400
    535
    I am afraid we do not offer that service.
  5. Carl B
    Nov 22, 2017
    7
    @DFP
    Maybe a bridge would help in your scenario? I would imagine you would get 50 SP's per instance, although you would most likely have pains with prefix codes etc.
  6. DFP
    DFP
    Nov 3, 2015
    11
    Carl B,
    I might look into a bridge. We run two different companies, but we currently have 1 unified phone system which is EOL 9/1/19.
    I am guessing a bridge would have to start with another prefix correct ? IE a number plus their extension number?
  7. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,610
    243
    @DFP
    Correct. You can either use the same extension numbering in both instances with a prefix to dial across the bridge or you can use non overlapping extension ranges.
  8. DFP
    DFP
    Nov 3, 2015
    11
    so I could do a range and then do routing between the two 3cx instances?
    IE 6000 to 6500 and then do the reversal on the other instance ie 1000-5000? I would prefer to have their extension match and keep four digit dialing.
    Bridging kind of sounds like tie lines between pbxs?
    Can inbound sip calls be routed to this other instance as well using bridging
    Thank Again for answer my question @cobaltit ?
  9. cobaltit
    Mar 22, 2012
    1,610
    243
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Hi, Just to let you know we are increasing the number of Parking Orbits in the next service pack....
  11. DFP
    DFP
    Nov 3, 2015
    11
    Nick,
    Thank for the update. What will the new limit be?
  12. Nick Galea
    Jun 6, 2006
    1,971
    280
    Good question - 250. It will require a new install as we have to reserve the ports during the installation so they cannot be used by something else.
  13. cobaltit
    Mar 22, 2012
    1,610
    243
    Hey Nick... nice to see this being added. Will restoring a backup count as a new install for this purpose?
