Parking via Handset "not allowed" 3CX V10
Discussion in '3CX Phone System - General' started by hkwylie, Jul 15, 2011.
  1. hkwylie
    May 13, 2011
    9
    We just switched to 3CX v10. One of our users is having an issue parking a call from her YeaLink T26P phone. She pushes transfer>>*00 (or 01,02,03…) as stated in the manual for proper parking procedure. Upon doing do, she receives a “not allowed” message.
    Is there a setting that needs to be changed so she can park calls without using the 3CX MyPhone?
    Thanks,
    Heather
  2. willow
    willow Member
    Mar 1, 2011
    471
    Check your license status in the system. i am thinking that is in not activated.
  3. hkwylie
    May 13, 2011
    9
    Thanks for the response! =)
    Unfortunately, I checked and it is in fact licensed for 3CXPSENT.
    Any other ideas?
    Thanks!
  4. leejor
    10,844
    299
    If it is only one user that is having the issue, then I would look at the set options. If other users don't have a problem , then it isn't a 3CX issue. The 3CX server log may help in debugging what the set is actually doing.
  5. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    this only seems to work if doing a blind transfer to *00
