Parse Error
Discussion in '3CX Phone System - General' started by KenC, Apr 12, 2012.
  1. KenC
    Mar 29, 2012
    85
    I am able to make outgoing calls through spa 3102 without problems. I am able to receive most calls, also without problem, although I was never able to get the 3102 to register.
    However, calls from some sources don't get through. Here isthe server log from a recent unanswered incoming call:
    17:57:48.687 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    @ .\ParseBuffer.cxx:949
    17:57:32.703 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    17:57:24.703 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    17:57:20.703 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    17:57:18.703 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    17:57:17.703 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    17:57:17.203 Exception thrown in TransactionStatehandleBadRequest. This shouldn't happen. ParseException .\ParseBuffer.cxx:949, Parse failed unexpected eof in context: From
    COHEN
    I've fiddled with various settings in the spa3102, including eliminating the "*"from PTSN Caller ID Pattern.
    Would appreciate guidance.
    thank you.
  2. KenC
    Mar 29, 2012
    85
    Correction: I've got the spa3102 showing as registered(idle).
  3. leejor
    10,859
    301
    Yeah...I would leave that * out of there.
    I'm wondering if your issue is in any any way related to this one, with the commas in CID...
    http://www.3cx.com/forums/parse-exception-thrown-on-cid-name-with-spa3102-19467.html#p98275
  4. KenC
    Mar 29, 2012
    85
    Thank you. If that's the problem does that mean there is no solution with this hardware/software? Does the Patton gateway have the same issue?
  5. leejor
    10,859
    301
    I'm not sure if any other gateways have the same issue. I would have thought that by now there would have been a firmware fix for this. A new version, for the 3102, just came out in the last month or so, you may want to download and give that a shot.
    The use of a comma in caller ID seems to be rare and only sent by a few companies.
    You could always shorten the PSTN Answer Delay to zero, but of course, you won't get any Caller ID
