Solved ParseException in ParseBuffer.cxx
Discussion in '3CX Phone System - General' started by lee3cxp, Oct 23, 2017.
  1. lee3cxp
    Oct 23, 2017
    I am getting the below ParseException error in ActivityLog. Phone calls work fine it just shows up and I'd like it to be addressed.
    I am using 3CX PRO 15.5.3849.1.
    10/23/2017 2:27:38 PM - Exception: ParseException ParseBuffer.cxx:87, Parse failed Expected "
    " in context: Contents
    Messages-Waiting: no
    Message-Account: sip:1777xxxxx@callcentric.com
    Voice-Message: 0/0 (0/0)
    Fax-Message: 0/0 (0/0)
    None: 0/0 (0/0)
    ^ @ ParseBuffer.cxx:87
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,142
    178
    I don't think anyone has gotten a definitive answer on this issue and there are several threads with similar parsebuffer errors. Some seem benign, others have caused problems.
    https://www.3cx.com/community/threa...y-log-query-csta-parseexception-events.49861/
    Basically if you can get PCAPs and full support packages when it happens then hopefully you can get that to 3CX support and they can track it down.
    Good luck!
    #2 cobaltit, Oct 23, 2017
  3. StefanW
    Jun 2, 2009
    1,217
    89
    this is know to be there when using callcentric.
    It is uncommon that a voip provider sends your 3CX MWI messages (voice mail status). But as callcentric also has some call frwd related services (de-facto you are an extension in there service and this is why they send MWI ).
    It can be savely be ignored!
  4. cobaltit
    Mar 22, 2012
    1,142
    178
    Good to know, thanks for the update Stefan.
