Pass the "Other" parameter to CRM
Discussion in 'CRM / Helpdesk / App Integration' started by Scott O'Brien, Jan 31, 2018.
  1. Scott O'Brien
    Mar 17, 2017
    We link our CRM to the company directory via an ODBC connection. It works very well. However the next step for us is to launch the CRM (in this case its Tikit's Partner for Windows) via a link handler app provided by Tikit. This will work for us but from the company directory on the %Callerdisplayname% and %CallerNumber% fields are available to pass as parameters. We need the unique client code in our CRM which is stored in the "Other" field in the directory.
    Is there any way around this?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    No, unfortunately there is no way to get that field from the 3CX client, and pop that URL.
  3. Scott O'Brien
    Mar 17, 2017
    Ok thanks, I thought as much. I changed the fields round so the code we need is the display name and it works fine.
    Cheers
    OB
