Passing-on DN CLID to an external SIP provider
Discussion in 'Windows' started by Kris2k, Jun 9, 2010.
  1. Kris2k
    Dec 12, 2009
    16
    I'm scratching my head on what may not necessarily be a desired "feature", but I figure I'd ask.
    I want to pass-on in the Remote Party ID / Calling Party ID / User Part, the DN of the extension who's calling the Trunk for accountability purposes.
    My first reflex would be to use the CallerNum because of it's parenthesis mentioning From->User, however that doesn't use the calling extension number, but instead the calling virtual port number used by 3CX.
    Any ways in achieving this? Are there variables that can be used in the custom fields property?
    Cheers
    Kris
