Solved Password After Provisionen yealink deckt w56p
Discussion in '3CX Phone System - General' started by Michael Walter, Mar 31, 2018.
  1. Michael Walter
    Mar 31, 2018
    15
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,249
    202
    edit the FXS/Dect unit, you need to use the 'Device Web Page' Password on the general tab
  3. Michael Walter
    Mar 31, 2018
    15
    Can you give me a screenshot please, where .
    Iam not native English, also the 3cx gives me a headache Since i try to get it right since days,
    So please help for dummies would be appreciated
  4. Legop
    Feb 22, 2018
    15
    Hi Michael, for the W56P the username is 'admin'.
    The password can be found here:
    I got stuck there aswell, but eventually figured it out. Intuition makes you try the credentials on the extensions properties. Yet for these DECT stations, it's in a different place and the username is not stated. There's probably room for improvement as people new with 3CX get stuck here deploying a Yealink DECT phone.
  5. Michael Walter
    Mar 31, 2018
    15
    Thanks it worked
    Mike
