Password failed
Discussion in '3CX Phone System - General' started by pip-k, Nov 1, 2006.
  1. pip-k
    Nov 1, 2006
    8
    Having installed 3CX, I am unable to log in and get the following error
    An error "500" has occured
    Internal server error
    SQLSTATE[08006] [7] FATAL: password authentication failed for user "admin"
    #0 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\CallContext.php(31): PDO->__construct('pgsql:dbname=ph...', 'admin', 'letmein')
    #1 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\fExtension.php(30): CallContext->getConnection()
    #2 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\fObject.php(19): fExtension->getData()
    #3 C:\Program Files\3CX\PhoneSystem\Data\Http\index.php(7): fObject->getManager()
    #4 {main}
    Cheers Philip
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    311
    password is incorrect
    the error means that you are inputting a different password from what you originally entered. If you forgot your password you would need to re-install
  3. pip-k
    Nov 1, 2006
    8
    Thanks for the reply. I have re-installed the prog. 6 times with the same result.The last time I used admin and a password of 1 as in
    #0 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\CallContext.php(31): PDO->__construct('pgsql:dbname=ph...', 'admin', '1')
    #4 {main}
    Could it be something to do with a NAT firewall? I thought the login was on the host PC.???. As you can tell I don't know what I'm doing.javascript:emoticon(':wink:')
    Wink
    Cheers
    Philip
  4. Anonymous
    Anonymous Guest
    I'm having exactly the same problem, same error message :roll: .
    Any help would be greatly appreciated
    Dan
  5. pip-k
    Nov 1, 2006
    8
    I don't know if this is significant??
    3CX Phone System v2.0.657.0 Status: Unknown
    Time Action Call ID Call source Call destination Message
    20:58:22.953 >>> Log started >>>
    20:58:23.015 ** Adding transports **
    20:58:23.015 ** Initialize DUM **
    20:58:23.015 ** Initialize Server Authentication **
    20:58:23.015 ** Initialize Client Authentication **
    20:58:23.109 SL: connected philip:0/MediaServer at [philip]/MediaServer
    20:58:23.109 Media Server is connected
    20:58:23.921 ** Initialize Lines Manager **
    20:58:25.656 !! Database connection failure: 'pqxx::broken_connection'
    20:58:26.671 !! Database connection failure: 'pqxx::broken_connection'
    20:58:27.687 !! Database connection failure: 'pqxx::broken_connection'
    Any thoughts
    cheers
    Philip
