password forgotten
Discussion in '3CX Phone System - General' started by spec, Jan 7, 2007.
  1. spec
    Sep 8, 2006
    51
    I have forgotten my admin password is there anyway to recover it or we looking at a reinstall????????
    thanks
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    305
    Unfortunately its a re-install. If it was easy to recover then it would also be insecure.
  3. spec
    Sep 8, 2006
    51
    Thought so
    thanks
