Paste A Number
Discussion in 'iOS' started by altitude, Nov 25, 2015.
  1. altitude
    Nov 15, 2015
    26
    I copied a number from a website I wish to call and couldn't workout how or where to paste a number.
    How is this done?
    Thanks,
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Thank you for your email,
    The number can be copy/paste in the space where the 3CX logo is.
    Regards
  3. altitude
    Nov 15, 2015
    26
    I tried to paste by single tap, double tap and holding with no success.
    I'm using an iPhone 6.
    What else do you suggest?
  4. healthy
    Oct 26, 2012
    30
    I just tried this, single, double, triple tap, tap and hold... no dice...
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    69
    Since paste means, basically, an attempt to dial a number, it obeys the same rules as a normal dial attempt.
    Therefore, to check if you really can paste something, tap a digit - if it doesn't appear on the display, then the paste will not work too; conveniently, if it appears, the paste should work too. Also, be sure you have something to paste.
    Paste occurs if you long-press the display for about 1 sec - on release, the "paste" menu appears.
    In normal conditions, we weren't able to reproduce your issue.
    Hope it helps
    vali
  6. altitude
    Nov 15, 2015
    26
    Okay, the way I got it working was to press any number on the dial pad and where that number shows press and hold to the right of that number and the paste option appears.
    Just pressing and holding over the 3CX logo did nothing.
