Patton 4112 as FXS for analogue fax device
Discussion in '3CX Phone System - General' started by level421, Jun 14, 2013.
  1. level421
    Dec 10, 2012
    Hello 3cx-Forum,
    I want to connect a Patton SN4112 as FXS for analogue fax devices.
    The Patton has HW-Revision 4.4 and SW-Version 5.8.
    It is currently configured as fxs with the 3cx (with the provided template in the 3cx-blog), but the faxes sent from the fax device connected to the patton are not sent to the 3cx server.
    Can anyone give me hints how to configure the Patton that faxes are sent correctly? What menues are relevant for the configuration of the voice ports?
    Regards,
    Matthias
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    3CX does not support sending of faxes, only receiving.
    Before we get into how the 4112 might be configured, can you tell us how the system is set-up relative to how it is connected to the "world". In other words, are you using SIP trunking, PRI, PSTN, etc.?
