Patton 4112 Configuration
Discussion in '3CX Phone System - General' started by dnut, Mar 23, 2017.
Tags:
  1. dnut
    Dec 19, 2016
    10
    I'm not able to make this gateway up and running.
    I followed the instructions here: https://www.3cx.com/voip-gateways/patton-smartnode-sn4112/
    I firstly upgraded Patton 4112 to the last available firmware
    Then configured SIP Trunk as explained in the guide
    I loaded the config file in the Patton
    Then I configured a generic outbound rule.
    I'm able to receive calls, but unable to make an outbound call.
    Any idea?
    Thank you for the support
    Here the screenshot of the configurations: https://goo.gl/photos/zNq6kar7DxB2WaYH6
    Here the log of a single call attempt (also attached here): https://drive.google.com/file/d/0BxXe6dpaQIPqeHQ4Vmc0bG55dDA/view?usp=sharing
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Can we get the config file you're using in the patton as well please ?
    ... might need you to SSH in to the patton and turn on fxo debugging :
    enable
    configure
    debug ccfxo
    debug fxo
    debug call-control
    debug call-router
    debug context sip-gateway transport
    debug context sip-gateway error
    ... don't forget to turn off debugging (if you turn it on) : no debug all
