Patton 4114 2 port FXS and 2 port FXO Setup
Discussion in '3CX Phone System - General' started by GWN, Dec 11, 2007.
  1. GWN
    GWN
    Dec 10, 2007
    60
    Could someone tell me how to setup the Patton? I've got 2 FXO ports and 2 FXS ports. I want to plug in 2 BT analogue lines into the FXO ports, and 2 wireless DECT phones into the FXS ports and use them as additional extensions. But for some reason 3CX will only see 4 FXO ports!
    Please could someone point me in the right direction as I'm quite new to setting up VoIP and 3CX.
    Thank you!
    Andy
  2. GWN
    GWN
    Dec 10, 2007
    60
    Please does anyone have any ideas? Anyone at all? :cry:
  3. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    Hello configure the PSTN Gateway with Patton 4 port FXO and then during installation change number of port to 2 from 4 it will reduce the number of FXO port to 2 form 4. this way you can configure the 2 FXO ports of Patton. Now create the 2 extension and configure those in PAtton device through web browser of the device. i hope this will help you for selecting the gateway setting for FXO ports in 3cx.
    I haven't tried this but i am sure that this will work in your case.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Have you try to seek help from Patton? Don't wested your time. I think just a fewwwwww peoples unable to config Patton's gateway manually. Let me know following details:
    3CX BOX IP
    Extension number for FXS0 and Password
    Extension number for FXS1 and Password
    Virtual extension number for FXO0 and Password
    Virtual extension number for FXO1 and Password
    FXO0 port target extension number
    FXO1 port target extension number
    Then send email to me 5qg4(a)ccx.ath.cx . I will send the config for you as soon as I can.
  5. GWN
    GWN
    Dec 10, 2007
    60
    If you choose less than 4 ports 3CX doesn't generate the config file for you, so I created a 4 port one and then edited the config to get rid of the additional ports. When I tried to create the FXS ports using the web configuration I get a bit confused and I couldn't get it working. :(
    Thanks very much for the offer 5qg4, I've emailed you the details! :)
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Sent. Please check you mailbox.
  7. GWN
    GWN
    Dec 10, 2007
    60
    Excellent! Thank you very much Ricky! :)
    I can now use phones plugged into the FXS ports although for some reason there is a 10 second delay before they hit the 3CX server when calling out from them.
    The only other thing is when I try and use a VoIP phone to make a call on the FXO port it rings the phone connected to the FXS port instead, so I can't make any non-VoIP outbound calls. The 3CX server reports that the 10001 PSTN line is ringing, not the 102 extension so I know it's not the 3CX server that has the problem.
    Any ideas? Thanks for all the help so far!
    Andy
  8. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi GWN,
    Regrading to "10 second delay", please apply following steps:
    1. Login your gateway via web admin
    2. Go to Call-Router
    3. Click Configuration
    4. Enable Digit-Collection Timeout
    5. set 4 seconds as Default Timeout
    6 Click apply
    or
    Change "no digit-collection timeout" instead of "digit-collection timeout 4" at config file then import again.
    I also hit this issue at V5. I will try to fix it as soon as I can.
  9. GWN
    GWN
    Dec 10, 2007
    60
    Thanks Ricky that's sorted the timeout! :)
    You've been so helpful, if you can let me know when you fix the FXO port problem I'll paypal you a thank you.
    Thanks,
    Andy
  10. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The problem should be been fixed. Please check you mailbox. The new config file already sent. Let me know works at your side or not.
  11. oneobserver
    Nov 12, 2007
    22
    Would it be possible for you to post this config somewhere? I have the same box and the web interface for this thing has got to be the most non-intuitive one I have ever found. I'll also email you and request a copy that way. I managed to get the FXO ports up but am having trouble with the FXS side of things.
    markh aka oneobserver
  12. GWN
    GWN
    Dec 10, 2007
    60
    To be honest I found that it wasn't worth setting it up this way as we had problems with lagging calls, calls still ringing after we've hung up and various other weirdness. In the end we bought a couple of Linksys PAP2T's instead which allowed us to plug in 4 standard phones. I configured them in about 1 minute each and they can be taken home and connect in over existing VPN's. :)
  13. jfk
    jfk
    Oct 22, 2012
    Attached my config for the 4114 with 2 FXS and 2 FXO ports;
    All you have to do is change the following values to your values and load the config in your Patton
    IP_GATEWAY IP Gateway (10.3.1.254)
    IP_PATTON IP Patton Device (fixed, not DHCP) (10.3.1.50)
    SUBNET_NETWORK Subnet your network (255.255.0.0)
    IP_3CXPBX IP 3CX Gateway (10.3.1.1)
    3CX_EXT_1 Extention number for FXS 0
    3CX_EXT_2 Extention number for FXS 1
    3CX_EXT_1_NAME Name extention FXS 0
    3CX_EXT_2_NAME Name extention FXS 1
    3CX_EXT_1_PWD Password Extention FXS 0
    3CX_EXT_2_PWD Password Extention FXS 1
    3CX_TRUNK1 Port identification VOIP Gateway FXO 0
    3CX_TRUNK2 Port identification VOIP Gateway FXO 1
    3CX_TRUNK1_PWD Authentication password VOIP Gateway FXO 0
    3CX_TRUNK2_PWD Authentication password VOIP Gateway FXO 1
    in 3CX; create your VOIP Gateway with the wizard for the 2 FXO ports
    in 3CX; create your Extentions using the patton templates found here: http://www.3cx.com/blog/wp-content/uploads/Patton-FXS-devices.zip (view tutorial http://www.3cx.com/blog/voip-howto/patton-fxs-gateway-at/ )
  14. jfk
    jfk
    Oct 22, 2012
    Updated version; now Caller ID works on the FXS ports
