- Joined
- Aug 6, 2007
- Messages
- 5
- Reaction score
- 0
Help: Using a Patton 4114 gateway.
Lines all register, but when connecting to outside line the call does not go through. Any ideas?
Config file below
system
ic voice 0
low-bitrate-codec g729
profile ppp default
profile tone-set default
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
profile pstn default
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface eth0
ipaddress 192.168.10.10 255.255.255.0
context cs switch
no digit-collection timeout
interface sip sipif0
bind gateway sipgw0
service default
route call dest-service fxohuntgroup
address-translation outgoing-call from-header user-part fix 10000 host-part local-ip
interface sip sipif1
bind gateway sipgw1
service default
address-translation outgoing-call from-header user-part fix 10001 host-part local-ip
interface sip sipif2
bind gateway sipgw2
service default
address-translation outgoing-call from-header user-part fix 10002 host-part local-ip
interface sip sipif3
bind gateway sipgw3
service default
address-translation outgoing-call from-header user-part fix 10003 host-part local-ip
interface fxo fxoif0
route call dest-interface sipif0
disconnect-signal battery-reversal
disconnect-signal busy-tone
use profile tone-set default
interface fxo fxoif1
route call dest-interface sipif1
interface fxo fxoif2
route call dest-interface sipif2
interface fxo fxoif3
route call dest-interface sipif3
service hunt-group fxohuntgroup
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
drop-cause user-busy
route call 1 dest-interface fxoif0
route call 2 dest-interface fxoif1
route call 3 dest-interface fxoif2
route call 4 dest-interface fxoif3
context cs switch
no shutdown
gateway sip sipgw0
bind interface eth0 router
service default
domain 192.168.10.2
authentication 10000 password 10000 default
default-server 192.168.10.2 loose-router
registrar 192.168.10.2
user 10000
gateway sip sipgw0
no shutdown
gateway sip sipgw1
service default
domain 192.168.10.2
authentication 10001 password 10001 default
user 10001
gateway sip sipgw1
no shutdown
gateway sip sipgw2
service default
domain 192.168.10.2
authentication 10002 password 10002 default
user 10002
gateway sip sipgw2
no shutdown
gateway sip sipgw3
service default
domain 192.168.10.2
authentication 10003 password 10003 default
user 10003
gateway sip sipgw3
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port fxo 0 0
use profile fxo us
encapsulation cc-fxo
bind interface fxoif0 switch
no shutdown
port fxo 0 1
use profile fxo us
bind interface fxoif1 switch
no shutdown
port fxo 0 2
use profile fxo us
bind interface fxoif2 switch
no shutdown
port fxo 0 3
use profile fxo us
bind interface fxoif3 switch
no shutdown
Config file below
system
ic voice 0
profile ppp default
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface eth0
context cs switch
bind gateway sipgw0
service default
bind gateway sipgw1
service default
bind gateway sipgw2
service default
bind gateway sipgw3
service default
context cs switch
no shutdown
gateway sip sipgw0
service default
domain 192.168.10.2
user 10000
gateway sip sipgw0
no shutdown
gateway sip sipgw1
service default
domain 192.168.10.2
user 10001
gateway sip sipgw1
no shutdown
gateway sip sipgw2
service default
domain 192.168.10.2
user 10002
gateway sip sipgw2
no shutdown
gateway sip sipgw3
service default
domain 192.168.10.2
user 10003
gateway sip sipgw3
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port fxo 0 0
use profile fxo us
no shutdown
port fxo 0 1
use profile fxo us
no shutdown
port fxo 0 2
use profile fxo us
no shutdown
port fxo 0 3
use profile fxo us
no shutdown
