Patton 4114 FXO
Discussion in '3CX Phone System - General' started by ossiejnr, Feb 23, 2016.
  1. ossiejnr
    Feb 23, 2016
    I've got a Patton 4114 FXO gateway and I wish to set this up so that when outbound calls are made they are sent to specific lines and not just the first one that is available.
    I believe I can do this by adding 4 different Gateways with different virtual extensions and then basically merging the generated configs in to one and uploading this to the Patton. I'm wondering if anybody has done this and can share a config or point me in the direction of a way to achieve this? Otherwise I'll roll up my sleeves and give it a go and see if I can get it working....
  2. AlexanderHanna
    Oct 2, 2015
    79
    10
    Here you go, this works for me.
  3. ossiejnr
    Feb 23, 2016
    That is ace - thank you so much
  4. bob222
    Oct 3, 2015
    17
    Thank you AlexanderHanna. This worked perfectly for me and I didn't fry my brain trying to figure it out myself.
