Patton 4114 FXS gateway
Discussion in '3CX Phone System - General' started by llbol, Jan 28, 2009.
  1. llbol
    Jan 22, 2009
    I am looking for a config for a patton 4114 FXS gateway.
    Does anyone has an example for me?
    Regards,
    Laurens
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    HI
    We do not have one at this stage, however we shall put this on the Wiki once he have something at hand.
  3. Minik
    Oct 9, 2008
    6
    Here's an example of configuration file. You have to fill in the <...> with your own ip adresses, phone number and passwords.
    In 3cxphonesystem, don't create a Pstn gateway. You just need to create the fxs extensions, as if it were SIP phones.
    I installed five SN4118JS, and it works fine.
    Hope it is helpfull.
    Regards
    Dominique
    Note : in the R5.2 release, the commands are different. This configuration file doesn't work in R5.2...
    # Configuration file for Patton SN4114JS (FXS) R4.2 #
    cli version 3.20
    webserver port 80 language en
    sntp-client
    sntp-client server primary <sntp1 ip address> port 123 version 4
    sntp-client server secondary <sntp2 ip address> port 123 version 4
    system
    ic voice 0
    low-bitrate-codec g729
    profile ppp default
    profile call-progress-tone defaultDialtone
    play 1 1000 440 0
    profile call-progress-tone defaultAlertingtone
    play 1 1500 440 -7
    pause 2 3500
    profile call-progress-tone defaultBusytone
    play 1 500 440 -7
    pause 2 500
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_LAN
    ipaddress <Gateway ip address> <Lan ip mask>
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    context cs switch
    no digit-collection timeout
    routing-table called-e164 Table1
    route .%T3 dest-interface IF_SIP_0
    routing-table called-e164 Table2
    route .%T3 dest-interface IF_SIP_1
    routing-table called-e164 Table3
    route .%T3 dest-interface IF_SIP_2
    routing-table called-e164 Table4
    route .%T3 dest-interface IF_SIP_3
    interface sip IF_SIP_0
    bind gateway GW_SIP_0
    service default
    route call dest-interface IF_FXS_0
    remote <3cx serveur ip address>
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <USER1 phone number> host-part call
    interface sip IF_SIP_1
    bind gateway GW_SIP_1
    service default
    route call dest-interface IF_FXS_1
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <USER2 phone number> host-part call
    interface sip IF_SIP_2
    bind gateway GW_SIP_2
    service default
    route call dest-interface IF_FXS_2
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <USER3 phone number> host-part call
    interface sip IF_SIP_3
    bind gateway GW_SIP_3
    service default
    route call dest-interface IF_FXS_3
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <USER4 phone number> host-part call
    interface fxs IF_FXS_0
    route call dest-table Table1
    call-transfer
    caller-id-presentation pre-ring
    subscriber-number <USER1 phone number>
    interface fxs IF_FXS_1
    route call dest-table Table2
    call-transfer
    subscriber-number <USER2 phone number>
    interface fxs IF_FXS_2
    route call dest-table Table3
    call-transfer
    subscriber-number <USER3 phone number>
    interface fxs IF_FXS_3
    route call dest-table Table4
    call-transfer
    subscriber-number <USER4 phone number>
    context cs switch
    no shutdown
    gateway sip GW_SIP_0
    bind interface IF_IP_LAN router
    service default
    domain <3cx serveur ip address>
    defaultserver manual <3cx serveur ip address> loose-router
    registration-lifetime 300
    registration manual <3cx serveur ip address>
    user <USER1 phone number> authenticate password <USER1 password> default register
    no shutdown
    gateway sip GW_SIP_1
    call-signaling-port 5062
    service default
    user <USER2 phone number> authenticate password <USER2 password> default register
    no shutdown
    gateway sip GW_SIP_2
    call-signaling-port 5064
    service default
    user <USER3 phone number> authenticate password <USER3 password> default register
    no shutdown
    gateway sip GW_SIP_3
    call-signaling-port 5066
    service default
    user <USER4 phone number> authenticate password <USER4 password> default register
    no shutdown
    port ethernet 0 0
    medium auto
    no shutdown
    port fxs 0 0
    caller-id format bell
    encapsulation cc-fxs
    bind interface IF_FXS_0 switch
    no shutdown
    port fxs 0 1
    bind interface IF_FXS_1 switch
    no shutdown
    port fxs 0 2
    bind interface IF_FXS_2 switch
    no shutdown
    port fxs 0 3
    bind interface IF_FXS_3 switch
    no shutdown
  4. llbol
    Jan 22, 2009
    Finaly I've got it working.
    It is used in Holland with firmware 5.3
    Regards,
    laurens
    # SN4114/JS/EUI #
    # R5.3 2009-01-15 H323 SIP FXS FXO #
    # 2009-02-18T08:44:12 #
    # SNasasdasdE #
    # Generated configuration file #
    cli version 3.20
    sntp-client
    sntp-client server primary <Your-SNTPServer port 123 version 4
    system
    ic voice 0
    profile ppp default
    play 1 1000 425 0
    codec 1 g711alaw64k rx-length 30 tx-length 30
    codec 2 g711ulaw64k rx-length 30 tx-length 30
    codec 3 g729 rx-length 30 tx-length 30
    rtp traffic-class local-default
    dejitter-mode static-data
    fax transmission 1 bypass g711ulaw64k
    fax transmission 2 bypass g711alaw64k
    fax transmission 3 relay t38-udp
    fax redundancy low-speed 2 high-speed 4
    fax dejitter-max-delay <Phonenumber2>
    no fax error-correction
    no fax hdlc
    fax max-bit-rate 9600
    no fax ced-retransmission
    fax bypass-method v150-vbd
    modem transmission 1 bypass g711alaw64k
    modem transmission 2 bypass g711ulaw64k
    modem bypass-method v150-vbd
    profile ringing-cadence default
    play 1 1000
    pause 2 4000
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_LAN
    ipaddress <IPAddress-Patton> <SubnetMask-Patton>
    context cs switch
    route .%T dest-interface IF_SIP_0
    route .%T dest-interface IF_SIP_1
    route .%T dest-interface IF_SIP_2
    route .%T dest-interface IF_SIP_3
    bind context sip-gateway GW_SIP_0
    remote <IPAddress-3CXServer>
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <Phonenumber1> host-part fix <IPAddress-3CXServer>
    address-translation outgoing-call diversion-header host-part remote
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <Phonenumber2> host-part fix <IPAddress-3CXServer>
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <Phonenumber3> host-part fix <IPAddress-3CXServer>
    early-connect
    early-disconnect
    address-translation outgoing-call from-header user-part fix <Phonenumber4> host-part fix <IPAddress-3CXServer>
    call-transfer
    subscriber-number <Phonenumber1>
    call-transfer
    subscriber-number <Phonenumber2>
    call-transfer
    subscriber-number <Phonenumber3>
    call-transfer
    subscriber-number <Phonenumber4>
    context cs switch
    no shutdown
    authentication-service default
    username <Phonenumber1> password 111111111111 encrypted
    username <Phonenumber4> password 222222222222 encrypted
    username <Phonenumber2> password 333333333333 encrypted
    username <Phonenumber3> password 444444444444 encrypted
    location-service default
    domain 1 <IPAddress-3CXServer>
    identity <Phonenumber1>
    display-name <Phonenumber1>
    phone-context <Phonenumber1>
    authentication outbound
    authenticate 1 authentication-service default username <Phonenumber1>
    registration outbound
    registrar <IPAddress-3CXServer>
    lifetime 3600
    register auto
    retry-timeout on-system-error 10
    retry-timeout on-client-error 10
    retry-timeout on-server-error 10
    identity <Phonenumber4>
    display-name <Phonenumber4>
    phone-context <Phonenumber4>
    authenticate 1 authentication-service default username <Phonenumber4>
    lifetime 3600
    register auto
    identity <Phonenumber2>
    display-name <Phonenumber2>
    phone-context <Phonenumber2>
    authenticate 1 authentication-service default username <Phonenumber2>
    lifetime 3600
    register auto
    identity <Phonenumber3>
    display-name <Phonenumber3>
    phone-context <Phonenumber3>
    authenticate 1 authentication-service default username <Phonenumber3>
    lifetime 3600
    register auto
    interface if_sip
    bind interface IF_IP_LAN context router port 5060
    bind location-service default
    no shutdown
    port ethernet 0 0
    medium auto
    no shutdown
    port fxs 0 0
    no shutdown
    port fxs 0 1
    no shutdown
    port fxs 0 2
    no shutdown
    port fxs 0 3
    no shutdown
