- Joined
- Jun 22, 2012
- Messages
- 5
- Reaction score
- 0
Hi, I installed a Patton Gateway 4114 (4xFXO) onto the 3CX Version 12.
I used the standard configuration as per the instructions in 3CX and uploaded the configuration file to the Patton gateway.
I'm only using 2 of the 4 fxo ports.
It was all working ok for a couple of weeks and then some of the handsets couldn't dial out over the Patton. I tried to reconfigure it, reset to factory settings etc, but now I cant get any phones to dial out via the Patton. I have 2 outgoing rules, dial 5 to route out via Patton, or 9 to dial out over the VoIP provider.
Incoming calls on the Patton and VoIP are working correctly. Dialing out over the VoIP is working.
It's only dialing OUT over Patton where there is an issue.
Strange thing as well, even when it was working, if you dialed out via the Patton, it would use ports 10008 and 10009, even though those two FXO ports where not being used. I was only using FXO 0 and FXO 1 on the Patton, which in my mind should be port 10006 and 10007 in 3CX.
So not sure how these things work together??
Version of Firmware in Patton: R6.4 2013-09-05
3CX - Version 12 with SP1
Any help appreciated.
