Patton 4114 only one port?
Discussion in '3CX Phone System - General' started by cfive, Feb 19, 2016.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Hi, I haven't installed a Patton 4114 in a while - not since v11. But on a clean install of v14, and provisioning two of these via the 3cx console, the Patton's only show 1 port. Can that be right?
    I do have a few v11 running and a v11 to 14 upgrade running, and they both show the 4114 with the expected 4 ports.
    But I also read that Patton shows ports as a single (hunt group) in 3cx, whereas Welltech shows individual ports?
    So I'm confused ;-). Should each 4114 show 4 ports?
    Thanks, Les
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Thanks, I read the instructions multiple times ;-).
    So I guess it's not an error. What confuses me, is that upgrades from v11 > through 12 > 14 - the Patton's show all the ports.
    Is that normal?
  4. NickD_3CX
    Jun 2, 2014
    1,367
    83
    Yes, the reason for that is that the Template as well as the Management Console config (along with the current config you have with 4 ports) is passed onto V14 through the backup.
    I would recommend giving the new template a spin if you have a second gateway at see if you prefer it, quite a few users have found it much easier to maintain, especially now that you can create a DID Inbound Rule for each FXO port (step 7 of the guide).
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    442
    73
    When was this added? That's a great feature that negates any negative the new template had. Thanks for pointing that out I will use that with my deployment next week!
  6. NickD_3CX
    Jun 2, 2014
    1,367
    83
    If memory serves it was with SP1 of V14.
    Also make sure you have the latest Patton template from the Management Console -> Updates -> PSTN Gateway Template Updates before going through the Wizard as it does include some important fixes.
