Patton 4114
Discussion in '3CX Phone System - General' started by chico, Mar 8, 2017.
  1. chico
    Mar 8, 2017
    12
    hi, I setup the Patton on my 3cx and upload the file to the patton.
    I can make or receive any call.
    # For Patton 2 to 8 FXO
    # Supported firmware versions R6.x
    # Author: Tommaso Missoni
    # Contact: support@patton.com
    webserver port 80 language en
    system
    ic voice 0
    low-bitrate-codec g729
    sntp-client
    sntp-client server primary pool.ntp.org
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 1000 350 -13 440 -13
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 400 400 -19 450 -19
    pause 2 200
    play 3 400 400 -19 450 -19
    pause 4 2000
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 375 400 -24
    pause 2 375
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 400 400 -24
    pause 2 350
    play 3 225 400 -24
    pause 4 525
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    play 1 400 400 -24
    pause 2 350
    play 3 225 400 -24
    pause 4 525
    profile tone-set default
    profile voip default
    codec 1 g711ulaw64k rx-length 20 tx-length 20 silence-suppression
    codec 2 g711alaw64k rx-length 20 tx-length 20 silence-suppression
    codec 3 g729 rx-length 20 tx-length 20 silence-suppression
    fax transmission 1 relay t38-udp
    profile pstn default
    echo-canceler-hybrid-loss 0
    echo-canceler-nlp silence
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface IF_IP_LAN
    ipaddress 192.168.1.183 255.255.255.0
    context cs switch
    routing-table called-e164 RT_SIP_TO_FXO
    route .% dest-service HG_TO_FXO
    routing-table called-e164 RT_FXO_00_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_00
    routing-table called-e164 RT_FXO_01_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_01
    routing-table called-e164 RT_FXO_02_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_02
    routing-table called-e164 RT_FXO_03_TO_SIP
    route default dest-interface IF_SIP MT_CALL_ID_03
    mapping-table called-e164 to called-e164 MT_CALL_ID_00
    map .% to 000000
    mapping-table called-e164 to called-e164 MT_CALL_ID_01
    map .% to 000001
    mapping-table called-e164 to called-e164 MT_CALL_ID_02
    map .% to 000002
    mapping-table called-e164 to called-e164 MT_CALL_ID_03
    map .% to 000003
    service hunt-group HG_TO_FXO
    drop-cause destination-out-of-order
    drop-cause user-busy
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_FXO_0
    interface sip IF_SIP
    bind context sip-gateway GW_SIP
    early-disconnect
    route call dest-table RT_SIP_TO_FXO
    remote 192.168.1.224 5060
    trust remote
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
    interface fxo IF_FXO_0
    route call dest-table RT_FXO_00_TO_SIP
    loop-break-duration min 60 max 1000
    caller-id format etsi
    ring-number on-caller-id
    mute-dialing
    disconnect-signal loop-break
    disconnect-signal busy-tone
    dial-after dialtone
    interface fxo IF_FXO_1
    route call dest-table RT_FXO_01_TO_SIP
    mute-dialing
    dial-after dialtone
    interface fxo IF_FXO_2
    route call dest-table RT_FXO_02_TO_SIP
    mute-dialing
    dial-after dialtone
    interface fxo IF_FXO_3
    route call dest-table RT_FXO_03_TO_SIP
    mute-dialing
    dial-after dialtone
    context cs switch
    no shutdown
    authentication-service AS_ALL_LINES
    realm 1 3CXPhoneSystem
    username 10000 password ch3qyjd
    location-service LS_10000
    domain 1 192.168.1.224
    identity-group default
    authentication outbound
    authenticate 1 authentication-service AS_ALL_LINES username 10000
    identity 10000
    registration outbound
    registrar 192.168.1.224 5060
    lifetime 300
    register auto
    register auto
    interface LAN
    bind interface IF_IP_LAN context router port 5060
    bind location-service LS_10000
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_LAN router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    bind interface IF_IP_WAN router
    no shutdown
    port fxo 0 0
    use profile fxo gb
    encapsulation cc-fxo
    bind interface IF_FXO_0 switch
    no shutdown
    port fxo 0 1
    use profile fxo gb
    bind interface IF_FXO_1 switch
    no shutdown
    port fxo 0 2
    use profile fxo gb
    bind interface IF_FXO_2 switch
    no shutdown
    port fxo 0 3
    use profile fxo gb
    bind interface IF_FXO_3 switch
    no shutdown
    context cs
    no IF_FXO_1
    no IF_FXO_2
    no IF_FXO_3
    port fxo 0 1
    shutdown
    port fxo 0 2
    shutdown
    port fxo 0 3
    shutdown
    Patton Log:
    2017-03-08T14:55:16 : LOGINFO : Link up on interface ethernet 0 0 0
    2017-03-08T14:55:17 : LOGINFO : Link up on interface IF_IP_LAN
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 19: SN4114/JO/EUI(ic-voice)[0]#sntp-client
    2017-03-08T14:55:23 : LOGWARNING : Config: % ^ Keyword mismatch
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 21: SN4114/JO/EUI(ic-voice)[0]#sntp-client server primary pool.ntp.org
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 226: SN4114/JO/EUI(prt-eth)[0/0]#port ethernet 0 1
    2017-03-08T14:55:23 : LOGWARNING : Config: % Ethernet port does not exist
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 259: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_1
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 260: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_2
    2017-03-08T14:55:23 : LOGWARNING : Config: Line 261: 192.168.1.183(ctx-cs)[switch]#no IF_FXO_3
    2017-03-08T13:55:23 : LOGINFO : Timezone: set local clock offset to +00:00
    % local time changed from 2017-03-08T14:55:23 to 2017-03-08T13:55:23
    2017-03-08T13:55:25 : LOGINFO : Warm start.
    Can someone help me???
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Are you using the config file generated by 3cx ???
  3. chico
    Mar 8, 2017
    12
    Yes, I upload the generate file by 3cx and reload the Patton.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Is the gateway registered to your 3cx ?
  5. chico
    Mar 8, 2017
    12
    Yes is registered
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    and you've got just 1 line plugged in to port 0/0 ?
    Do you see anything in the 3cx activity log when a call comes in on that line ?
    Did you setup outbound rules to use the gateway ?
    Have you turned on debugging in the patton (debug ccfxo, debug fxo, debug call-control, debug call-router, debug context sip-gateway transport, debug context sip-gateway error) and if so what do you see ??
    .... seriously, show your work! ;) The more you explain the easier it'll be to fix.
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,509
    468
    What firmware version is the patton running?
  8. chico
    Mar 8, 2017
    12
    Yes I have a working line on the 0/0 port.
    3cx log when I tried make a outbone call
    03/08/2017 3:06:25 PM - Call to T:Line:10000>>xxxxxxxx@[Dev:sip:10000@192.168.1.183:5060] from L:5.1[Extn:100] failed, cause: Cause: 503
    Service Unavailable/INVITE from 192.168.1.183:5060
    Yes I make I outbone rule to make this call
    About the debugging mode on Patton, really, I don't understand anything.
    Firmware version:R6.7 2015-01-06 H323 SIP FXS FXO
  9. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    what about the activity log for inbound calls ?
    Are you sure you have an active line plugged in the correct port ?? Have you confirmed with an analog phone ? Is there a stuttered dial-tone perhaps on the line to indicate messages in a telco mailbox ?
  10. chico
    Mar 8, 2017
    12
    This is the outbone call
    If I connect a phone, I have tone, only for make a outside call I need press first the number 9.
    When I tried to make a inbound call, anything is going inside to the server
  11. chico
    Mar 8, 2017
    12
    If i make a call to the number, and go to call-router- active call on patton, I don't see anything.
    Is like the patton, don't receive nothing
  12. GiannosC_3CX
    GiannosC_3CX Guest
  13. chico
    Mar 8, 2017
    12
    O.k, I upgrade the firmware of the Patton, but I have another issue.
    When I go to install a new Gateway, and install the FXS, I don't have the option on 3cx.
    How I can install the template, and from where I can download or copy or something like this?
  14. GiannosC_3CX
    GiannosC_3CX Guest
    Hi chico,
    For FXO you need to go under SIP Trunk and then click on Add gateway. Then you need choose the Patton Analog FXO option and add the number ports. When you finish your configuration you can generate your device config and then upload it to your device.
  15. chico
    Mar 8, 2017
    12
  16. GiannosC_3CX
    GiannosC_3CX Guest
  17. chico
    Mar 8, 2017
    12
    No, I need the FXS.
    But the problem is I don't have the option to installer on my 3cx.
    I tried to setup like FX0, but obviously don' work.
    The link you give is what I want, but I don't have the option.
    My 3cx is update to the last one
  18. GiannosC_3CX
    GiannosC_3CX Guest
    Hi chico,
    Did you try to add FXS/DECT from management console? (management console => FXS/DECT )
    Did you mean this options? Did you full the Mac Address field?
    Please clarify what you mean "I do not have the option".
    Could you please send us a screenshot
  19. chico
    Mar 8, 2017
    12
    Yes, this is what i have
  20. GiannosC_3CX
    GiannosC_3CX Guest
    Hi ,
    To add FXS you need to go to management console and the click on the FXS/DECT a popup window appear, please see the following screenshot.
    and then you can configure your device
    I hope the above is useful to you.
    Please let us know If you need any further information.
    #20 GiannosC_3CX, Mar 10, 2017
