patton 4114
Discussion in '3CX Phone System - General' started by manolo, Apr 21, 2008.
  1. manolo
    Apr 21, 2008
    7
    I have and use the viop gateway Patton SN-4114 - config generated from 3CX, and imported to SN-4114
    in 3CX line status i can see extensins (work OK) and generated PSTN lines (cant make a call)
    3CX Phone System Version5.1.4393.0
    patton 4114 R4.2 2007-09-19 H323 SIP FXS FXO
    problem: no tone on FXS port's and i can not make a call from this port's
    Sincerely,
    Manolo
  2. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    What country are you using this in?
  3. manolo
    Apr 21, 2008
    7
  4. manolo
    Apr 21, 2008
    7
    Only me have this problem????
    Once more, do I have right?
    On 3CX system I add PSTN lines (Patton SN4114) and created config. import into Patton with factory default settings. After that I expect that I can make a call with other extensions on the system, and 4 devices on patton.
    THX
    M.
  5. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    It is possibly a problem with the call progress tones settings on the Patton but I am afraid I have no idea what they should be for Croatia. Have you tried the help on Patton's site?
    If you telnet the Patton rather than http to it you can turn on debugging functions and see what is happening when you try and place a call.
    You could also try posting the server logs here and someone may be able to help further.
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Did you check your outbound rules for that gateway? Dial 8 or dial 9 etc?
  7. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    The 3CX template system for the SN-4114 is designed for this model: SN4114/JO/EUI
    It is the 4xFXO model.
    Is the model you are using?
    Regards
    Kevin
  8. manolo
    Apr 21, 2008
    7
    4114/js/eui
  9. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    The SN-4114/JS/EUI is effectively NOT A GATEWAY.
    It is a 4-port ATA device.
    You will need to configure this device manually.
    Regards
    Kevin
  10. manolo
    Apr 21, 2008
    7
    Hay
    Can you tell me how to configure device?
    That part whit gateway
    Thx for information ...
