Patton 4114
Discussion in '3CX Phone System - General' started by ccs0142, Jan 5, 2009.
  1. ccs0142
    Dec 3, 2008
    No problems with the 3 cx phone works very well, except when i try to configure the outbound rules with the patton 4114. I only get the choice of the patton 4114 and not individual lines. is there anyway i can split these into 4 lines.
    thanks
      File size:
      123.1 KB
      686
  2. AlecM
    Aug 24, 2007
    52
    What you are seeing is the normal 3CX configuration behaviour, the same as in previous versions of 3CX.
    It specifies dialling 9 as a prefix to call any external number.
    3CX will check which PSTN line is free on the 4114 and automatically use a free line.
    You can monitor this activity on the Line/Trunk Status page.
  3. ccs0142
    Dec 3, 2008
    Thanks for your reply. you have cleared that up for me. 8)
    Dave
