Patton 4144 - Bad gateway
Discussion in '3CX Phone System - General' started by it4group, Oct 8, 2010.
  1. it4group
    Sep 29, 2008
    I've setup a Patton 4114 using the wizard making sure the firmware was the 5.3 as stated. But when making outgoing call via the voip soft phone, I get server failure. Below is the log from the 3cx any help would be grateful I'm a bit losted as to what is wrong.
    Code:
    11:08:17.437  [CM503020]: Normal call termination. Reason: Server Failure
    11:08:17.437  [CM503016]: Call(4): Attempt to reach <sip:907540705416@192.168.100.9:5060> failed. Reason: Server Failure
    11:08:17.436  [CM503003]: Call(4): Call to sip:07540705416@192.168.100.51:5060 has failed; Cause: 502 Bad Gateway; from IP:192.168.100.51:5060
    11:08:17.255  [CM503025]: Call(4): Calling PSTNline:07540705416@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:08:17.254  [MS210006] C:4.2:Offer provided. Connection(by pass mode): 192.168.100.11:40036(40037)
    11:08:17.215  [CM503004]: Call(4): Route 1: PSTNline:07540705416@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:08:17.212  [CM503010]: Making route(s) to <sip:907540705416@192.168.100.9:5060>
    11:08:17.211  [MS210000] C:4.1:Offer received. RTP connection: 192.168.100.11:40036(40037)
    11:08:17.209  Remote SDP is set for legC:4.1
    11:08:17.209  [CM505001]: Ext.303: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13679.0] PBX contact: [sip:303@192.168.100.9:5060]
    11:08:17.205  [CM503001]: Call(4): Incoming call from Ext.303 to <sip:907540705416@192.168.100.9:5060>
    11:08:17.196  [CM500002]: Info on incoming INVITE:
      INVITE sip:907540705416@192.168.100.9:5060 SIP/2.0
      Via: SIP/2.0/UDP 192.168.100.11:60672;branch=z9hG4bK-d8754z-1650a35d6352b463-1---d8754z-;rport=60672
      Max-Forwards: 70
      Contact: <sip:303@192.168.100.11:60672;rinstance=a78fdbf2544bc3cd>
      To: <sip:907540705416@192.168.100.9:5060>
      Call-ID: YzE4ZjJkODEzNTI2MDc0ODFhNGI3OWJiYjI3ZjE3Njk.
      CSeq: 2 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
      Proxy-Authorization: Digest username="303",realm="3CXPhoneSystem",nonce="414d535c02bf7e9080:1ada9f66b10fc74eacddd806cd7598f8",uri="sip:907540705416@192.168.100.9:5060",response="b8c3e2e509a632f91cda311947583bdb",algorithm=MD5
      Supported: replaces
      User-Agent: 3CXPhone 4.0.13679.0
      Content-Length: 0
    11:08:03.539  Currently active calls [none]
    11:07:38.965  [CM503020]: Normal call termination. Reason: Server Failure
    11:07:38.965  [CM503016]: Call(3): Attempt to reach <sip:9202@192.168.100.9:5060> failed. Reason: Server Failure
    11:07:38.964  [CM503003]: Call(3): Call to sip:202@192.168.100.51:5060 has failed; Cause: 502 Bad Gateway; from IP:192.168.100.51:5060
    11:07:38.781  [CM503025]: Call(3): Calling PSTNline:202@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:07:38.779  [MS210006] C:3.2:Offer provided. Connection(by pass mode): 192.168.100.11:40034(40035)
    11:07:38.737  [CM503004]: Call(3): Route 1: PSTNline:202@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:07:38.734  [CM503010]: Making route(s) to <sip:9202@192.168.100.9:5060>
    11:07:38.733  [MS210000] C:3.1:Offer received. RTP connection: 192.168.100.11:40034(40035)
    11:07:38.732  Remote SDP is set for legC:3.1
    11:07:38.731  [CM505001]: Ext.303: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13679.0] PBX contact: [sip:303@192.168.100.9:5060]
    11:07:38.729  [CM503001]: Call(3): Incoming call from Ext.303 to <sip:9202@192.168.100.9:5060>
    11:07:38.723  [CM500002]: Info on incoming INVITE:
      INVITE sip:9202@192.168.100.9:5060 SIP/2.0
      Via: SIP/2.0/UDP 192.168.100.11:60672;branch=z9hG4bK-d8754z-e07e4e2564525500-1---d8754z-;rport=60672
      Max-Forwards: 70
      To: <sip:9202@192.168.100.9:5060>
      Call-ID: YjZlNzFkZDVhYmJiMjYwNGY5NTUxYzU1NTUxYzlkN2U.
      CSeq: 2 INVITE
      Proxy-Authorization: Digest username="303",realm="3CXPhoneSystem",nonce="414d535c02bf7e6a84:82e1f20cfb783c0defe93e966c62035a",uri="sip:9202@192.168.100.9:5060",response="a4f9b3454956c1ced7a701857452e8b2",algorithm=MD5
      Supported: replaces
      Content-Length: 0
    11:07:31.917  [CM503020]: Normal call termination. Reason: Not found
    11:07:31.917  [CM503016]: Call(2): Attempt to reach <sip:202@192.168.100.9:5060> failed. Reason: Not Found
    11:07:31.916  [CM503014]: Call(2): No known route to target: <sip:202@192.168.100.9:5060>
    11:07:31.914  [CM503010]: Making route(s) to <sip:202@192.168.100.9:5060>
    11:07:31.914  [MS210000] C:2.1:Offer received. RTP connection: 192.168.100.11:40032(40033)
    11:07:31.912  Remote SDP is set for legC:2.1
    11:07:31.912  [CM505001]: Ext.303: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13679.0] PBX contact: [sip:303@192.168.100.9:5060]
    11:07:31.909  [CM503001]: Call(2): Incoming call from Ext.303 to <sip:202@192.168.100.9:5060>
    11:07:31.903  [CM500002]: Info on incoming INVITE:
      INVITE sip:202@192.168.100.9:5060 SIP/2.0
      Via: SIP/2.0/UDP 192.168.100.11:60672;branch=z9hG4bK-d8754z-f85c912f6d6d0b36-1---d8754z-;rport=60672
      Max-Forwards: 70
      To: <sip:202@192.168.100.9:5060>
      Call-ID: NDJjNWEzNTA5M2YyYTg4YTBiZjIzMjA3NjU4YmVjYjY.
      CSeq: 2 INVITE
      Proxy-Authorization: Digest username="303",realm="3CXPhoneSystem",nonce="414d535c02bf7e6364:60400f3d09b3a15456c322227c3a4e5f",uri="sip:202@192.168.100.9:5060",response="a4fc5cbbfc9e0a35fb290c17509c88f6",algorithm=MD5
      Supported: replaces
      Content-Length: 0
    11:07:31.535  Currently active calls [none]
    11:07:25.797  [CM503020]: Normal call termination. Reason: Server Failure
    11:07:25.796  [CM503016]: Call(1): Attempt to reach <sip:907540705416@192.168.100.9:5060> failed. Reason: Server Failure
    11:07:25.782  [CM503003]: Call(1): Call to sip:07540705416@192.168.100.51:5060 has failed; Cause: 502 Bad Gateway; from IP:192.168.100.51:5060
    11:07:25.594  [CM503025]: Call(1): Calling PSTNline:07540705416@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:07:25.592  [MS210006] C:1.2:Offer provided. Connection(by pass mode): 192.168.100.11:40030(40031)
    11:07:25.548  [CM503004]: Call(1): Route 1: PSTNline:07540705416@(Ln.10000@NEWTON4114)@[Dev:sip:10000@192.168.100.51:5060]
    11:07:25.543  [CM503010]: Making route(s) to <sip:907540705416@192.168.100.9:5060>
    11:07:25.541  [MS210000] C:1.1:Offer received. RTP connection: 192.168.100.11:40030(40031)
    11:07:25.528  Remote SDP is set for legC:1.1
    11:07:25.528  [CM505001]: Ext.303: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.13679.0] PBX contact: [sip:303@192.168.100.9:5060]
    11:07:25.524  [CM503001]: Call(1): Incoming call from Ext.303 to <sip:907540705416@192.168.100.9:5060>
    11:07:25.175  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP 192.168.100.11:60672;branch=z9hG4bK-d8754z-6d076568c1177d07-1---d8754z-;rport=60672
      Max-Forwards: 70
      Call-ID: ZDY0MWI3MzZiN2FiZTM4NzNhNWI4MmRmMWJmYzBkMzU.
      CSeq: 2 INVITE
      Proxy-Authorization: Digest username="303",realm="3CXPhoneSystem",nonce="414d535c02bf7e5c10:88e3ba45b4b3470b5ee65c088ba75188",uri="sip:907540705416@192.168.100.9:5060",response="de8f3c112e7005065922f17aa6ce9f36",algorithm=MD5
      Supported: replaces
      Content-Length: 0
      CSeq: 2 INVITE
      Max-Forwards: 70
      Supported: replaces
      Content-Length: 0
      CSeq: 2 INVITE
    10,582
    249
    Do you receive incoming calls through the gateway? One common problem is that the gateway doesn't detect the (normally) 48 volts on the telephone line and will refuse to place the call. Does the Patton not have a log that may explain what is happening with the calls?
