Patton 4552 & 3CX
Discussion in '3CX Phone System - General' started by elbatech, Apr 30, 2008.
  1. elbatech
    Apr 30, 2008
    After installing successfully a Patton 4114 with 3CX, we did not succeed with a Patton 4552.
    We have carefully followed the steps indicated in "Configuring Patton Smart Node - 4554 / 4552 VOIP Gateway for 3CX Phone System" but at the end of the process (without any error) the Patton is listed with a red dot indicating that the system is not registered.
    We have used version R5.1_2008-03-12 which is the most recent. Unfortunately the above instructions alert that earlier and future versions with respect to 3.21 and 4.2 are not guaranteed to work with those instructions. By the way, we tried to downgrade to the 4.2 firmware version, without success.
    Can anybody explain what we are missing and support us to correctly install our device ?
    Below the cfg file is attached for a sake of completeness.
    Many thanks in advance,
    best regards
    Riccardo Galletti
    Code:
    # For SN-4552 1-port BRI
    # Author: Kevin Attard Compagno
    # Date: 2008-04-03
    # Contact: kevin@3cx.com
    webserver port 80 language en
    system
      ic voice 0
        low-bitrate-codec g729
    system
      clock-source 0 0
    profile ppp default
    profile call-progress-tone defaultDialtone
      flush-play-list
      play 1 200 425 0
      pause 2 200
      play 1 600 425 0
      pause 1 1000
    profile call-progress-tone defaultAlertingtone
      flush-play-list
      play 1 1000 425 -7
      pause 2 4000
    profile call-progress-tone defaultBusytone
      flush-play-list
      play 1 200 425 -7
      pause 2 200
    profile call-progress-tone defaultReleasetone
      flush-play-list
      play 1 250 425 -7
      pause 2 250
    profile call-progress-tone defaultCongestiontone
      flush-play-list
      play 1 250 425 -7
      pause 2 250
    profile tone-set default
    profile voip default
      codec 1 g711alaw64k rx-length 20 tx-length 20
      codec 2 g711ulaw64k rx-length 20 tx-length 20
      fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
      no autonomous-transitioning
    profile aaa default
      method 1 local
      method 2 none
    context ip router
      interface IF_IP_WAN
        ipaddress dhcp
    	tcp adjust-mss rx mtu
    	tcp adjust-mss tx mtu
      interface IF_IP_LAN
        ipaddress 192.168.1.1 255.255.255.0
    context cs switch
      mapping-table calling-pi to calling-e164 MP_REM_CLIR
        map restricted to ""
      routing-table called-e164 RT_ISDN_TO_SIP_0
        route T2 dest-interface IF_SIP_0 MP_REM_CLIR
      interface isdn IF_ISDN_0
        route call dest-table RT_ISDN_TO_SIP_0
      interface sip IF_SIP_0
        bind gateway GW_SIP_0
        service default
        route call dest-interface IF_ISDN_0
          remote-party-id called-party
    	    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
          address-translation incoming-call called-e164 request-uri
    context cs switch
      no shutdown
    gateway sip GW_SIP_0
      call-signaling-port 5060
      bind interface IF_IP_LAN router
      service default
        domain 192.168.1.2
        defaultserver manual 192.168.1.2 loose-router
        registration-lifetime 300
        registration manual 192.168.1.2
        user 10000 authenticate name 10000 password 10000 default register
      no shutdown
    port ethernet 0 0
      medium auto
      encapsulation ip
      bind interface IF_IP_WAN router
      no shutdown
    port ethernet 0 1
      medium auto
      encapsulation ip
      no shutdown
    port bri 0 0
      clock auto
      encapsulation q921
      q921
        protocol pmp
        uni-side auto
        encapsulation q931
        q931
          protocol dss1
          uni-side user
          encapsulation cc-isdn
          bind interface IF_ISDN_0 switch
    port bri 0 0
      no shutdown
