Patton 4552, Configuration
Discussion in '3CX Phone System - General' started by Dida28, Aug 8, 2007.
  1. Dida28
    Aug 8, 2007
    9
    i think 3cx is a great VOIP solution and we are thinking of buying the enterprise solution. But i have some problems with ISDN. I am new in VOIP and i hope you can help me with configure my Patton Smartnode 4552.
    I am from Germany and have an ISDN S0 Port, which is connected to the Patton Gateway.
    My 3cx works internal fine, and all phones can call internal.
    Now i want to connect my ISDN Port with with the Patton VOIP Gateway. I have configured my patton and i used this instruction:
    Configuring a Patton Smartnode ISDN for 3CX Phone System:
    http://www.3cx.com/voip-gateways/smartnode-isdn.html
    The 2 PSTN Lines register to 3cx now and all incoming calls, let the phones ring. But when i answer the call, i can hear anyone, and the other way around.
    One more problem is, that i can't call out to someone. When i want to make a outgoing call nothing happens on softphone and the logfile from 3cx says:
    [CM103002] Call(43): Incoming call from 102 (Ext.102) to sip:005151245845@192.168.0.1
    1 Minute after i cancel the Call because i will not connect:
    CM104007] Call(43): Call from Ext.102 to 008073916313 has been terminated by Ext.102; cause: CANCEL; from IP:192.168.0.13
    Here is my context cs:
    3CX = 192.168.178.41
    Patton = 192.168.178.1
    Code:
    context cs switch
      national-prefix 0
      international-prefix 00
      routing-table called-e164 RT_SPEED_DIAL
        route T dest-table RT_NR_BLOCKING MT_SPEED_DIAL
      routing-table called-e164 RT_NR_BLOCKING
        route default dest-table RT_CALL_ROUTING MT_SET_CNPN
      routing-table called-e164 RT_CALL_ROUTING
        route default dest-service SER_HG_PSTN_FALLBACK
      routing-table called-e164 RT_INCOMING
        route default dest-interface IF_S0_01 MT_NR_TRANSLATION
      mapping-table called-e164 to called-e164 MT_SPEED_DIAL
      mapping-table calling-e164 to calling-e164 MT_SET_CNPN
      mapping-table called-e164 to called-e164 MT_NR_TRANSLATION
      interface isdn IF_S0_00
        route call dest-table RT_INCOMING
      interface isdn IF_S0_01
        route call dest-table RT_SPEED_DIAL
        use profile tone-set Europe
        isdn-date-time
      interface isdn IF_DEV0
      interface isdn ISDN0
        route call dest-interface SIPIF0
      interface isdn ISDN1
        route call dest-interface SIPIF1
      interface sip IF_SIP_SERVICE
        bind gateway GW_SIP
        service default
        use profile voip VOIP
      interface sip SIPIF0
        bind gateway SIPGW0
        service default
        route call dest-interface ISDN0
        remote-party-id called-party
        address-translation outgoing-call to-header user-part fix 10001 host-part interface
        address-translation incoming-call called-e164 request-uri
      interface sip SIPIF1
        bind gateway SIPGW1
        service default
        route call dest-interface ISDN1
        address-translation outgoing-call to-header user-part fix 10002 host-part interface
      service hunt-group SER_HG_PSTN_FALLBACK
        timeout 6
        drop-cause normal-unspecified
        drop-cause no-circuit-channel-available
        drop-cause network-out-of-order
        drop-cause temporary-failure
        drop-cause switching-equipment-congestion
        drop-cause access-info-discarded
        drop-cause circuit-channel-not-available
        drop-cause resources-unavailable
        drop-cause no-route-to-destination
        route call 1 dest-interface IF_S0_00
        route call 2 dest-interface IF_SIP_SERVICE
    context cs switch
      no shutdown
    gateway sip GW_SIP
      bind interface IF_IP_WAN router
      service default
    gateway sip GW_SIP
      no shutdown
    gateway sip SIPGW0
      call-signaling-port 5062
      bind interface IF_IP_LAN router
      service default
        domain 192.168.178.41
        authentication 10001 password dZ8edXkjFnM= encrypted default
        default-server 192.168.178.41 loose-router
        registration-lifetime 120
        registrar 192.168.178.41
        user 10001
    gateway sip SIPGW0
      no shutdown
    gateway sip SIPGW1
      call-signaling-port 5064
      service default
        authentication 10002 password iAaKwKfxX4Q= encrypted default
        user 10002
    gateway sip SIPGW1
      no shutdown
    Can anybody give me a hint where the problem is?
    Thank you very much, nice greetings from munich
    Dida
    (Sorry for my bad english :? )
  2. marcoluce
    Jun 22, 2007
    9
    Hi Dida,
    I suggest first upgrading to a new Patton firmware from http://upgrades.patton.com, for example to R3.21 2007-05-14, then try again.
    Then, you appear having a configuration that is mixed between the original Patton configuration and the 3CX config steps (for example, you have 4 virtual "interface isdn" in your config, although your unit only has two physical ISDN ports, and although this is not necessarily broken, it can make your config complicated to read). Can you post your complete configuration file here?
    Cheers
    -Marco
