PATTON 4552
Discussion in '3CX Phone System - General' started by jits04, Jan 23, 2008.
  1. jits04
    May 2, 2007
    76
    I have created and upload the config file, but the line is still red (off). What can I check? I thought to find a session in the patton configuration where to put the password and id (like spa 3102 or similar)
    it seem that patton don't ask to 3cx to register it.
    Thank in advance.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try to check your LN registrar details by following steps:
    1. Web login your Patton gateway
    2. Click SIP
    3. Click the SIP gateway name
    4. Click the Services name (it should be named as "default" if you using default setting)
    5. Click the Registration and Authentication
  3. jits04
    May 2, 2007
    76
    In fact, I haven't SiP tab. Peraphs Have I wrong firmware?
    Model SN4552/2BIS/EUI
    Serial Number 00A0BA0348E6
    Hardware Version 2.1
    Software Version R4.2 2007-09-19 H323
    Can I load the sip version?
    Thanks again
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Oh I see.
    May be you can download the SIP version at following URL. However, I'm NOT sure that works at your existing gateway or not.
    http://upgrades.patton.com/list.asp?model=SmartNode%204552&flag=1
  5. jits04
    May 2, 2007
    76
    Yes! This was the problem. Register is ok now.
    Many thanks again.
    William
