Patton 4554 dail-out issue
Discussion in '3CX Phone System - General' started by Spyklee, Nov 1, 2007.
  1. Spyklee
    Nov 1, 2007
    45
    I'm a newbe to 3CX and currently have two issues with C3X v3 and a Patton 4554.
    Although the Patton has 2 BRI connectors currenlty only BRI-1 is connected. BRI-0 is not connected.
    I I try to dail-out with my LinkSys SPA942 it shows the error message
    [CM103005] Call(6) is rejected: Service Unavailable
    [CM104008] Call(6): Call from Ext.102 to 06XXXXXXXX terminated; cause: 503 Service Unavailable; from IP:10.1.9.1
    [CM103002] Call(6): Incoming call from 102 (Ext.102) to sip:06XXXXXXXX@10.1.8.6
    Active Calls in the Patton:
    Call Call-Leg State Address Display Charge
    00821060
    sipif0-00822f08/acti CONNECTED 102 n/a n/a
    router-00821560/inco TRYING 06XXXXXXXX n/a n/a
    0081fab8
    router-00821560/outg CONNECTED 102 n/a n/a
    isdnif0-00819b90/act TRYING 06XXXXXXXX n/a n/a
    If the Patton is trying to use the BRI-0 port to dail out (isdnif0) it seems logical I'm not able to dail out, since only BRI-1 is connected to the provider. However in 3CX I configured that virtual number 1001 is the dail-out line. Is this not connected to the BRI-1?
    Is it possible to connect virtual number 10001 to the second BRI?
    Another issue is the caller-id, I used V4 prior to downgrade to V3. Within V4 I had no caller-id at all. Wihtin v3 it's truncating the first digit.
    I noticed it's within the Patton already truncated:
    00818948
    isdnif1-00824098/act CONNECTED 6XXXXXXXX n/a n/a
    sipif1-00822c98/acti ALERTING 7XXXXXXXX n/a n/a
    I've also an Asterisk PABX running the caller-id within Asterisk is working fine. Most likely a Patton issue as well.
    Any ideas?
    Cheers! Eric
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Post the Patton gateway's config file here for us to investigate your issue.
  3. Spyklee
    Nov 1, 2007
    45
    Ricky,
    Thank you for your reply, I've created with V4 the following config file:
    Code:
    webserver port 80 language en
    system
      ic voice 0
        low-bitrate-codec g729
    system
      clock-source 0 0
    profile ppp default
    profile call-progress-tone NL_Dialtone
      flush-play-list
      play 1 1000 425 0
    profile call-progress-tone NL_Alertingtone
      flush-play-list
      play 1 1000 425 -7
      pause 2 4000
    profile call-progress-tone NL_Busytone
      flush-play-list
      play 1 500 425 -7
      pause 2 500
    profile call-progress-tone NL_Releasetone
      flush-play-list
      play 1 250 425 -7
      pause 2 250
    profile call-progress-tone NL_Congestiontone
      flush-play-list
      play 1 250 425 -7
      pause 2 250
    profile tone-set NL_default
      map call-progress-tone dial-tone NL_Dialtone
      map call-progress-tone ringback-tone NL_Alertingtone
      map call-progress-tone busy-tone NL_Busytone
      map call-progress-tone release-tone NL_Releasetone
      map call-progress-tone congestion-tone NL_Congestiontone
    profile tone-set default
    profile voip default
      codec 1 g711alaw64k rx-length 20 tx-length 20
      codec 2 g711ulaw64k rx-length 20 tx-length 20
    profile voip fax_enabled
      fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    profile aaa default
      method 1 local
      method 2 none
    context ip router
      interface eth0
        ipaddress 10.1.9.1 255.0.0.0
        tcp adjust-mss rx mtu
        tcp adjust-mss tx mtu
    context cs switch
      interface isdn isdnif0
        route call dest-interface sipif0
        use profile tone-set NL_default
      interface isdn isdnif1
        route call dest-interface sipif1
      interface sip sipif0
        bind gateway sipgw0
        service default
        route call dest-interface isdnif0
        remote-party-id called-party
        address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
        address-translation incoming-call called-e164 request-uri
      interface sip sipif1
        bind gateway sipgw1
        service default
        route call dest-interface isdnif1
        address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
    context cs switch
      no shutdown
    gateway sip sipgw0
      bind interface eth0 router
      service default
        domain 10.1.8.6
        authentication 10000 password 10000 default
        default-server 10.1.8.6 loose-router
        registrar 10.1.8.6
        user 10000
    gateway sip sipgw0
      no shutdown
    gateway sip sipgw1
      service default
        domain 10.1.8.6
        authentication 10001 password 10001 default
        registrar 10.1.8.6
        user 10001
    gateway sip sipgw1
      no shutdown
    port ethernet 0 0
      medium auto
      encapsulation ip
      no shutdown
    port bri 0 0
      clock auto
      encapsulation q921
      q921
        protocol pmp
        uni-side auto
        encapsulation q931
        q931
          protocol dss1
          uni-side user
          encapsulation cc-isdn
          bind interface isdnif0 switch
    port bri 0 0
      no shutdown
    port bri 0 1
      clock auto
      encapsulation q921
      q921
        protocol pmp
        uni-side auto
        encapsulation q931
        q931
          protocol dss1
          uni-side user
          bind interface isdnif1 switch
    port bri 0 1
      no shutdown
    Thanks in advance!
    Eric
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try to shutdown BRI 0 0
    port bri 0 0
    shutdown
    If the problem still not fixed. Then enable gateway's debug. Post the log as well.
    #debug ccisdn error
    #debug ccisdn signaling
    #debug isdn error
  5. Spyklee
    Nov 1, 2007
    45
    Thanks,
    I'll try this ...
    Any idea about the truncate of the first digit of the caller-id?
    Cheers!
    Eric
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Enable gateway's debug mode. Issue one call into to your Patton gateway. Capture the log then post here again. Since the config generated by 3CX. It should be a pink config file. There is not found any special digits mapping. Therefore, the 1st digit may be truncated by your provider. But I not sure, since different provider have different behavior. For me, my provider needs sent back the 8 digits full e164 calling party number. However, 3CX box unable to provide this function. It's default just can only use extension number as e164 calling party number. Therefore, I need to add the prefix 12345+ext# to make it as our calling party number. As I know that most gateways without this function. This function should handled by PBX. However, Patton's gateway did.
  7. Spyklee
    Nov 1, 2007
    45
    Thanks for the fast reply Ricky(!)
    Any idea where to find the debug option on the Gateway?
    Eric
  8. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please find the steps as below:
    1. Telnet to your Patton gateway
    2. key in userid and password
    3. gatewayname>enable then enter
    4. gatewayname#debug ccisdn error then enter
    5. gatewayname#debug ccisdn signaling then enter
    6. gatewayname#debug isdn error then enter
  9. Spyklee
    Nov 1, 2007
    45
    cool stuff the debugging:
    Code:
    SN4554/2BIS/EUI#16:39:33  ICC   > [isdnif1] << Message: primitive=64
    16:39:33  ICC   > [isdnif1] Added endpoint isdnif1-00820050
    16:39:33  ICC   > [isdnif1] NEW CALL. Allocated Endpoint isdnif1-00820050
    16:39:33  ICC   > [EP isdnif1-00820050] << [080005]
    SETUP (DSS1 User)
      [04038090A3]
      Bearer capability : speech - CCITT
        circuit mode - 64kBit/s - G.711 A-law
      [180189]
      Channel id : 1 - exclusive
        basic rate interface - is not d-channel - CCITT - b-channel units
      [6C0B2181363534363738393437]
      Calling party number : 6XXXXXXXX
        national number - E.164 numbering plan
        presentation allowed - user provided verified and passed
      [700AA1373537353031313330]
      Called party number : 7XXXXXXXX
      [7D029181]
      High layer compatibility : telephony
        CCITT
      [A1]
      Sending complete
    16:39:33  ICC   > [EP isdnif1-00820050] State: NULL, Event: TERMINAL SETUP IND
    16:39:33  ICC   > [EP isdnif1-00820050] Set state to CALL PRESENT
    16:39:33  ICC   > [EP isdnif1-00820050] Set state to INCOMING PROCEEDING
    16:39:33  ICC   > [EP isdnif1-00820050] >> [080002]
    CALL PROCEEDING (DSS1 User)
      [1E028582]
      Progress indicator : destination address is non-ISDN
        private network serving remote user - CCITT
    16:39:33  ICC   > [EP isdnif1-00820050] State: INCOMING PROCEEDING, Event: PEER
    TRYING
    16:39:33  ICC   > [EP isdnif1-00820050] Hold State: IDLE, Hold Event: PEER TRYIN
    G
    PROCEEDING
    16:39:33  ICC   > [EP isdnif1-00820050] Hold State: IDLE, Hold Event: PEER PROCE
    EDING
    ALERTING
    16:39:33  ICC   > [EP isdnif1-00820050] Set state to CALL RECEIVED
    16:39:33  ICC   > [EP isdnif1-00820050] >> [080001]
    ALERTING (DSS1 User)
    16:39:33  ICC   > [EP isdnif1-00820050] Hold State: IDLE, Hold Event: PEER ALERT
    ING
    16:39:40  ICC   > [isdnif1] << Message: primitive=50
    16:39:40  ICC   > [EP isdnif1-00820050] << [08004D]
    RELEASE (DSS1 User)
      [08028290]
      Cause : normal call clearing
        public network serving local user - CCITT - Q.931
    16:39:40  ICC   > [EP isdnif1-00820050] State: CALL RECEIVED, Event: TERMINAL RE
    LEASE IND
    16:39:40  ICC   > [EP isdnif1-00820050] Set state to NULL
    16:39:40  ICC   > [isdnif1] CLEARING CALL isdnif1-00820050
    16:39:40  ICC   > [isdnif1] Removed endpoint isdnif1-00820050
    16:39:40  ICC   > [isdnif1] Destroying finished calls.
    16:39:40  ICC   > [isdnif1] Destroyed endpoint isdnif1-00820050
    Seems that the first digit is not there either. How did you add the prefix so the caller-ID is shown correctly on the extensions?
    Thank you for all your support(!)
    Cheers, Eric
  10. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Referred to your debug log. The issue should be your provider pass the incomplete e164 calling party number to your BRI line. You should contact your Telco to fixed this issue. Since almost all the gateways won't truncated any digit(s) at calling party number. All the digits are from Telco. If the missed digit is fixed, the digit mapping at gateway will help to solved your issue. Otherwise, you must in need to work with your Telco to fixed the caller id issue.
  11. Spyklee
    Nov 1, 2007
    45
    Well, I've also an Asterisk server running, but this system has no issue with the caller-id number.
    Regards, Eric
  12. Spyklee
    Nov 1, 2007
    45
    Ricky,
    Called-ID is solved.
    Within the web-gui;
    Advanced-GUI>Telephony>Call-Router>Configuration>E.164 Number Prefixes
    You're able to adjust here the national prefex and the international prefix.
    Cheers!
  13. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Eric,
    Good to hear, your issue had been fixed. In your case, I also learn more at Patton's gateway. Since our region ISDN BRI for Video Conference only. Only ISDN PRI for telephony.
  14. Spyklee
    Nov 1, 2007
    45
    Ricky,
    I've tested the shutdown config for the BRI 0 but it seems the gateway is not redirecting the call to the second line. Must be a config somewhere in the gateway.
    to be continued ... :wink:
    Eric
  15. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try following options.
    AT GUI Admin mode > BRI 0 0 > Configuration
    Port State: disable
    (ISDN Layer 2):
    Permanent Activity: disable
    (ISDN Layer 3):
    Untick => Bind to BRI Interface
  16. Spyklee
    Nov 1, 2007
    45
    Ricky,
    If tested your settings, but it seems not te work.
    I've redirected sipif0 to isdnif1 instead of isdnif0 and that seems to work, but if both ISDN cables are plugged to the Patton, it will always use isdnif0 / BRI-0 to dail out, that is not the way it should work (I think).
    sipif0 should dail out on BRI-0
    sipif1 should dail out on BRI-1
    Look like there is a setting to always redirect to the sipif0/BRI-0.
    Eric
  17. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Eric,
    Any impact for if will always use isdnif0 / BRI-0 to dail out? How about if two extensions in-use at BRI 0. The 3rd one will use BRI-1 or get the busy tone? How about your calling party number? Is it working fine or not?
  18. Spyklee
    Nov 1, 2007
    45
    Ricky
    Good point!
    solution for me is to set the secondairy ISDN line to the BRI/0
    and the primary to the BRI/1 in that case the primary number will me at least available most of the times, even if 2 people are dailing out. Since they are using the secondairy ISDN on the BRI/0
    Thanks for all your help!
