patton 4634 only two simultaneous call allowed
Discussion in '3CX Phone System - General' started by luppazzo, Mar 4, 2010.
  1. luppazzo
    Apr 17, 2008
    I have a patton 4634 3bri and 2 ISDN lines in point-to-point configuration
    when receiving calls I get up to 4 simultaneous calls
    when dialing I am only allowed to do up to 2 simultaneous call
    any ide where to cahnge gateway configuration?
    this is the patton status:
    Domain: 192.168.0.2
    Local Address: 192.168.0.7:5060
    Remote Address: (none):0
    Default Server: 192.168.0.2:0;lr
    Early Proceeding: yes
    Hold using zero IP: yes
    Early Connect: no
    Early Disconnect: no
    Call-Transfer: accept & emit
    Call-Reroute: disabled
    AOC-D Information: accept
    Pull-In Externally Looped Calls: yes
    Address-Complete Indication: Accept: clear
    PhoneContext
    Use Calling Remote-Party-ID: no
    Use Called Remote-Party-ID: yes
    Use Privacy: no
    Outgoing Call Parameter Source
    From Header
    User: from call URI or E.164 ()
    Host-Port: from call URI or E.164 :)0)
    To Header
    Host-Port: from interface :)0)
    Request URI
    User: fix (10001)
    Host-Port: from To header :)0)
    Target Parameter: none (Target: , Cause: )
    Calling Remote-Party-ID Header
    Header User: from call URI or E.164 ()
    Header Host-Port: from call URI or E.164 :)0)
    Called Remote-Party-ID Header
    Header Host-Port: from interface :)0)
    Identity Header
    Diversion Header
    Header Host-Port: none :)0)
    Incoming Call Parameter Source
    Calling Party
    E.164: from Identity header ()
    URI: from Identity header ((invalid))
    Name: from Identity header ()
    Redirecting E.164: none (Target: , Cause: Unknown)
    Called Party
    E.164: from Request-URL ()
    URI: from Remote-Party-ID header ((invalid))
    Name: from Remote-Party-ID header ()
    Play Tones: yes
    VoIP Profile: default
    Used: by 2 module(s)
    Voice Codecs
    G.711 A-law: Rx=20ms Tx=20ms
    G.711 u-law: Rx=20ms Tx=20ms
    Fax Codecs
    T.38 UDP: Rx=1ms Tx=1ms Relay
    Modem Codecs
    Codec Negotiation: enabled
    Dejitter
    Mode: Adaptive
    Max. Delay: 60ms
    Max. Packet Loss: 4/1000
    Shrink Speed: 1
    Grow Step: 1
    Grow Attenuation: 1
    High Pass Filter: enabled
    Post Filter: enabled
    Fax
    Detection: CED Tone
    T.38 High Speed Redundant Packets: 0
    T.38 Low Speed Redundant Packets: 0
    Max. Bit Rate: 14400bps
    Volume: -9.500dB
    Error Correction: enabled
    HDLC: enabled
    Dejitter Max Delay: 200ms
    Modem
    Volume: -9.500dB
    HDLC: enabled
    DTMF
    Relay: enabled
    Mute Encoder: enabled
    RTP
    Payload Type NTE: 101
    Payload Type NSE: 100
    Payload Type Clearmode: 97
    Payload Type Redundancy: 255
    Payload Type G.726-32: 2
    Payload Type G.726-32-AAL2: 2
    BCD
    Avtivation: on-rx-activation
    Timeout: 1000
    Traffic Class: local-voice
    SIP Profile: default
    Autonomous Transitioning: disabled
    Tone-Set Profile: (none)
    Routing Destination: router (IF_SIP_0-precall-service)
    State: Up
    Allow New Calls: yes
    Allow Incoming Calls: yes
    Wait For Name: no
    Wait For Number: no
    Proceeding Timeout: 4000
    Early Alerting Timeout: 0
    Endpoints
    Endpoint: IF_SIP_0-00b69fd8
    Domain: 192.168.0.2
    Local Host: 192.168.0.7
    Local Port: 5060
    Remote Host: (none)
    Remote Port: (default)
    Default Server: 192.168.0.2/0 (loose-router)
    Session-Timer Interval: 0s
    Session-Timer Version: 8
    Call-Transfer Version: 5
    Early Connect: no
    Phone Context
    Play Tones: yes
    Call Routing Destination: router (IF_SIP_0-precall-service)
    Active State: Disconnected
    Passive State: Idle
    Endpoint: IF_SIP_0-009297b8
    Domain: 192.168.0.2
    Local Port: 5060
    Remote Host: (none)
    Early Connect: no
    Phone Context
    Play Tones: yes
    Active State: Connected
    Passive State: Idle
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    On the Management console, select the Patton 4634 Gateway, and in the outbound parameters tab kindly ensure they are set to "DevHostPort", if you are unusure kindly tell me what they are.
    RequestLineURI : Host Part
    To : Host Part
    Thanks,
  3. luppazzo
    Apr 17, 2008
    thank you for your prompt reply
    I have on the config
    Sip fileds:
    Request Line URI : Host Part "DevHostPort" source address/port
    To : Host Part "DevHostPort" source address/port
    Here's the config file for further check; can you see any other possible issue?
    Another technician suggested the problem was in the pp pmp configuration of ISDN line but I doublechecked with telco and they are all correct.
    # For SN-4634/3BIS/UI 3-port BRI
    # Author: Kevin Attard Compagno
    # Date: 2008-02-20
    # Contact: kevin@3cx.com
    webserver port 80 language en
    system
    ic voice 0
    low-bitrate-codec g729
    system
    clock-source 0 0
    profile ppp default
    profile call-progress-tone defaultDialtone
    flush-play-list
    play 1 200 425 0
    pause 2 200
    play 1 600 425 0
    pause 1 1000
    profile call-progress-tone defaultAlertingtone
    flush-play-list
    play 1 1000 425 -7
    pause 2 4000
    profile call-progress-tone defaultBusytone
    flush-play-list
    play 1 200 425 -7
    pause 2 200
    profile call-progress-tone defaultReleasetone
    flush-play-list
    play 1 250 425 -7
    pause 2 250
    profile call-progress-tone defaultCongestiontone
    flush-play-list
    play 1 250 425 -7
    pause 2 250
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    no autonomous-transitioning
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface IF_IP_LAN
    ipaddress 192.168.0.7 255.255.255.0
    context cs switch
    mapping-table calling-pi to calling-e164 MP_REM_CLIR
    map restricted to ""
    routing-table called-e164 RT_ISDN_TO_SIP_0
    route T2 dest-interface IF_SIP_0 MP_REM_CLIR
    routing-table called-e164 RT_ISDN_TO_SIP_1
    route T2 dest-interface IF_SIP_1 MP_REM_CLIR
    interface isdn IF_ISDN_0
    route call dest-table RT_ISDN_TO_SIP_0
    interface isdn IF_ISDN_1
    route call dest-table RT_ISDN_TO_SIP_1
    interface sip IF_SIP_0
    bind gateway GW_SIP_0
    %%earlymedia%%
    service default
    route call dest-interface IF_ISDN_0
    remote-party-id called-party
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
    interface sip IF_SIP_1
    bind gateway GW_SIP_1
    %%earlymedia%%
    service default
    route call dest-interface IF_ISDN_1
    address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
    context cs switch
    no shutdown
    gateway sip GW_SIP_0
    call-signaling-port 5060
    bind interface IF_IP_LAN router
    service default
    domain 192.168.0.2
    defaultserver manual 192.168.0.2 loose-router
    registration-lifetime 300
    registration manual 192.168.0.2
    user 10001 authenticate name 10001 password 10001 default register
    no shutdown
    gateway sip GW_SIP_1
    call-signaling-port 5062
    service default
    domain 192.168.0.2
    user 10002 authenticate name 10002 password 10002 default register
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface IF_IP_WAN router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    encapsulation cc-isdn
    bind interface IF_ISDN_0 switch
    port bri 0 0
    no shutdown
    port bri 0 1
    clock auto
    encapsulation q921
    q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    bind interface IF_ISDN_1 switch
    port bri 0 1
    no shutdown
    port bri 0 2
    clock auto
    encapsulation q921
    q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 2
    shutdown
  4. luppazzo
    Apr 17, 2008
    can anyone reply to the prevous post?
    thank you
