PATTON 4638
Discussion in '3CX Phone System - General' started by srose, May 20, 2008.
  1. srose
    May 2, 2008
    Hello
    I install a patton 4638 and then create a DID for Fax with a forward line to a non ISDN
    The forward works when calling a fixed line my does not send a fax
    calls from a fixed line was a good entree into 3CX not to send the Fax
    There exists an order that the patton to get the SDA there is a forwarder to another number
    Cordialement,
    Sylvain ROSE
    sylvain.rose@sbsconseil.com
    Tel : +33 (0)1 75 43 56 40
    Gsm : +33 (0)6 81 92 11 60
    Fax : +33 (0)1 72 33 55 19
    http://www.sbsconseil.fr
