Patton 4960 PRI Single Cadence Ring Tone
Discussion in '3CX Phone System - General' started by Discovery Technology, Apr 3, 2011.
  1. Discovery Technology
    Apr 19, 2008
    278
    For those of you situated in Australia wanting to implement a Primary Rate Patton ISDN Gateway in your environment, it may be useful to know that the default template generated by 3CX only provides a config with a single inbound ring tone cadence (possibly an American or European format).
    This can be easily changed to give your external callers dialling in a standard Australian ring tone. The safest method is to export your current working configuration, editing this file then re-importing it, followed by a reboot - this ensures that you don't lose any additional customisation work that you may have done if it is an established system, otherwise simply update the wizard-generated config file prior to importing if you are building a new system.
    Simply replace the tone set lines with the following:
    profile ppp default
    profile call-progress-tone defaultDialtone
    play 1 1200 400 -13 440 -13
    profile call-progress-tone defaultAlertingtone
    play 1 400 400 -13 440 -13
    pause 2 200
    play 3 400 400 -13 440 -13
    pause 4 2000
    profile call-progress-tone defaultBusytone
    play 1 400 425 -10
    pause 2 400
    profile call-progress-tone defaultReleasetone
    play 1 200 425 -10
    pause 2 200
    profile call-progress-tone defaultWaitingtone
    play 1 200 425 -10
    pause 2 200
    play 3 200 425 -10
    pause 4 4400
    profile tone-set default
    This process works and has been confirmed on several systems now. I would imagine that if changes are required for other countries that Patton support would be able to assist with the appropriate tone sets.
    I hope this helps you out if you come across this issue in the future.
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Thanks for that useful tip!
