patton 4970 not registering
Discussion in '3CX Phone System - General' started by stash, Jan 2, 2013.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    I have a patton 4970 and it seems after loading config from 3CX the gateway is still not registered. Followed the steps given by 3CX.
    Any idea?
    Thanks,
    STASH
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    can you ping/access the web interface?
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Sigma,
    Yes i can ping and access the web. But config from 3CX is not reflecting or loading on the device. I already did the factory reset. Roll back firmware but still no luck.
    Thanks,
    STASH
  4. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    I seem to remember that the SN4970 has two Ethernet ports labelled 0/0 and 0/1 ... You configure via the 0/0 port, but then connect it for operation on the 0/1 port after the 3CX configuration has been loaded into it.
    Had you done that???
    best regards
  5. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    4970 has only 1 Ethernet port which is 0/0. Maybe this hardware has defect are you sure that this device has 2 Ethernet port?
    Thanks,
    STASH
  6. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    Oops - sorry - its the 4960 that has the two ports ...
    Have you tried doing a firmware update? I've had a couple of Smart Nodes that have needed to be hit with a reset & firmware upgrade before they would behave.
  7. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    Yes i already loaded the latest firmware.
    Thanks,
    STASH
  8. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    Hi Stash
    After the config file dump from 3CX - are you able to browse the 4970 on its new IP address - or is it still on the default??
  9. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    Yes i can still access the patton after loading the config file. using the ip address i gave to it. But i don't see anything different on it and it's not registered on 3CX.
    Thanks,
    STASH
  10. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Fox,
    I already resolved the problem :) just created another gateway on the PSTN using 10001 Virtual number and it registered.
    So i have 2 patton devices 1 is not registered and the other is registered. i will check if i can make incoming and outgoing call.
    Thanks,
    STASH
  11. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    Hi Stash
    Thanks for the closure - interesting to see that changing the virtual line number resolved the issue. I've not seen that before and can't imagine why it would cause a problem - But - one more fact & fix for the tool-box!
    best regards
