Patton Call Pickup disconnects
Discussion in '3CX Phone System - General' started by simongurner, Jan 6, 2008.
  1. simongurner
    Nov 26, 2007
    We are using a patton 4114 with BT lines connected to each port. Connection to the system is fine and each line is authenticated, with the config file improted fine during setup.
    The problem we have though is everytime someone then picks up an incoming call, the call is then immendiately dropped (disconnected).
    Also, when ever we try to dial out, again the calls just get disconnect straight away.
    Has anyone got any ideas in where to look to solving this?
    Regards
    Simon Gurner
  2. robjbrad
    Dec 6, 2007
    6
  3. robjbrad
    Dec 6, 2007
    6
    Also, remove battery reversal from the disconnect signal options.
