Patton Firmware Version Supported by 3CX
Discussion in '3CX Phone System - General' started by star1, Feb 17, 2011.
  1. star1
    Apr 7, 2010
    40
    What's the current SmartWare version supported. The website says 5.3, but I know it was up to 5.4 in 8/2010. Has the version increased?
    Thanks,
    Eric Mandel
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hi,
    i have installed on some company 5.6 V and no error detected.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    The actual supported firmware version is 5.4m if you look at our guides it will always say the supported fimmware version.
  4. star1
    Apr 7, 2010
    40
    Thanks.
    Maybe I'm using the wrong guides. When I go to support at the top of the page and then select one of the patton guides, the pages still reference 5.3. See here: http://www.3cx.com/voip-gateways/patton-sn4960.html. It states the current supported version is 'Smartware 5.3 Build Series 2009-03-18'.
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    On that specific model that is the supported firmware. But we have tested 5.4 on other models and it passed all tests so it should be fine. Try it and see how you go.
