Patton FXO issue
Discussion in '3CX Phone System - General' started by PepePineda, Jul 13, 2016.
  1. PepePineda
    Oct 30, 2015
    13
    In order to make work OK on V15, you have to update its firmware to latest version and reprovission. I made a restore form my V14 backup and it disconnects after some minutes from system reboot
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Yes, you have updates on top and there is a specific section gateway, please update.
  3. PepePineda
    Oct 30, 2015
    13
    Althoug update, pbx losts connection and have to reboot it in order to recover connection
  4. Aram
    Aram Support Team
    May 7, 2012
    154
    30
    It looks like you have some bandwidth issues by this reason download of updates took that much time. Please do not download all updates. Please download only the new Patton gateway template.
    Then create a new Patton FXO device and provision you gateway.
