Patton FXS
mixig
can anyone provide me a template for Patton 4924/4932, i have some analog phones which i need connect to 3cx. I will change ip addresses and sip user, sip passwords...
3cx should generae the config file for you.
Ill informed answer, They are not currently supported and 3CX does not have an installed template to generate the file.
May I suggest you look into the Grandstream GXW-4024 instead?
Grandstream will work but are company is moving to patton instead of the exisiting grandstream ata...
Getting Started - Admin
damiano giannini
Get 3CX - Absolutely Free!
3CX
