Patton gateway config file generator - doesn't put gateway into config
Discussion in '3CX Phone System - General' started by JonnyM, Aug 11, 2016.
  1. JonnyM
    May 17, 2010
    79
    5
    I ran through these steps (http://www.3cx.com/voip-gateways/patton ... de-sn4112/) to configure an FXO gateway as a backup provider, and while it's pretty nice that 3CX builds the configuration for me, it doesn't write any default gateway details into the network configuration.
    This is more of a warning to anyone else before they lose access to any devices that might be on a separate subnet - check the config file before you apply it, and add a gateway.
  2. business54
    Apr 20, 2016
    56
    The same happens on the 4970 PRI gateway. Upload config breaks connectivity and you have to console in to resolve.
  3. felipeg007
    Jan 28, 2015
    18
    its been like that since version 12.5. we get the same results on 14 and 15sp5.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    ... are you guys crossing subnets ?
    Edit: just re-read the first post and he was crossing subnets. 3cx has always said they don't support gateways outside the network, so this is normal to have to do some manual configurations.
    Artik Lal likes this.
